Truck is  2025 Chevrolet 2500 HD Custom 6.6 Gas . Truck was built in Oshawa .
I have a couple of threads on here fellas but I thought I would just check something out .
Someone has told me that there is a recall or a special bulletin for the tranny on this truck . Is this true ?
Also where do I look for recalls and Special Bulletins for this truck ?
Thank You !
Doubtful on a 24'+
Gm "upgraded" the valve bodies in late 23'iirc to the Gen 3 version. No recall on them,,, yet.
I think Allison forcing Gm to not use their namesake after 26' will work in our favor. Hopefully, GM's hand will be forced to do a real, long term fix.
Thank You ! JW2024 and NoF-bdy Bs !
6 hours ago, No F-bdy Bs said:
Doubtful on a 24'+
Could you please explain the last sentence I'm not sure that I understand
Thank You
  • 5 months later...
There is a TSB.
https://static.nhtsa.gov/odi/tsbs/2025/MC-11014081-0001.pdf
My 24 3500 dually L8T with 28k on it had these symptoms so I dropped it off last week. Waiting on parts. It started while I was towing, tranny slipped and slammed into gear during a normal acceleration. I don’t pedal mash either, was towing about 10k at the time. It “slipped”, engine RPMs shot up and then it slammed into a low gear at about 40mph. From then on I was noticing odd downshifts and delayed engagement.
  • 1 month later...
So I got my truck back 2 weeks ago. It was running fine, towed well on a trip up to the farm with 16k on an equipment trailer. Then, hours after towing, I went to get groceries and the transmission took a complete dump on me on the way home. Turned on to the road and it went into some super weird limp mode where it would only go about 10mph, was unresponsive to throttle input and would just randomly lurch forward. It was quite difficult getting it off the busy road. Tried disconnecting and reconnecting the battery to see if it was something dumb in the computer. It worked for about 100 feet and then went back into limp/lurch mode. So I had it towed to the dealer on the Sunday of Memorial Day weekend since I didnt want it sitting on the side of the road. Dealer got back to work today so it is in the hopper to get looked at.
My service advisor has been absolutely amazing through this process. The initial 3 weeks it was laid up really sucked since this is a commercial truck and our primary equipment hauler, but he really did his best to expedite the repairs. We will see what comes of this visit. I have no doubts that my dealer will be great, the shortfall will come with big GM who refuses to admit they have some sort of issue with this transmission. Just all TSBs with no increased parts support.
Following. I have 31K on my 2024 HD. The most I have towed so far is about 12K I have not had any transmission issues yet.
Alright so this one ended up being a different TSB that was not related to the transmission at all. It was the O2 sensor wire that got too close to the exhaust and melted. I guess the 5v reference wire melted, shorted out and caused about 200 codes to populate and the truck to go into limp mode.
https://static.nhtsa.gov/odi/tsbs/2024/MC-10253570-0001.pdf
  • 3 weeks later...
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
    • What are your thoughts? The Chevy Blazer relaunch was an epic case of 'lunchbag letdown'. Jeep Wranglers and Ford Broncos stick out like a sore thumb.    The AI photos do not look like a 'retro version', but shrunken Tahoes. Get away from the 'futuristic look'. I've seen two concepts. One had rectangular headlight like a Rivian and the other way too big headlights (similar to a previous non-Wrangler SUV) should include dual round headlights like the early version.   If not this would look OK   At least it has GM styling (albeit the K2XX) A lot of the images floating around look like Bronco IIs or the current Bronco. Looking at the Broncos in my area (central Ontario, it seems to be a mix of 2 doors and 4 doors, 'mall rated' to ones that could go offroad.    I'm sure a AT4 and AT4X RPOs could be outfitted similar to a Rubicon if the braintrust understood the whole offroad scene. Crossing my fingers that if it does see the light that the front air dam/bumper doesn't extend below the center line of the tire...
    • I saw this news earlier this year:   https://theautowire.com/2026/06/12/gm-kills-off-chevys-biggest-silverado-trucks-as-sales-collapse-and-factory-fallout-spreads/
