Hey, I've seen a few posts on this topic, but nothing is very clear. I own a 2017 Silverado 1500 that I imported from Canada. I'd like to have the "normal" headlights with the amber lights activated as parking lights and be able to turn them off whenever I want, outside of automatic mode. Is there a solution for this? From what I've seen, it's all about programming. Could you shed some light on this?
PS: I'm in Europe.
Thanks in advance.
For my '12 3500, I added a switch in the circuit from the bcm to the low-beam circuit going to the fuse box, to turn off the headlights at night, primarily for parking w/o flashing the headlights into the neighbors house.
You probably will have to do something like this.  Or possibly a company like white automotive media can flash your bcm to make it work as you want.
PS: I'm in Europe.
Thanks in advance.
In the states when we get imported from Canada GM vehicles, GM made it clear that they can't and won't support re-flashing the BCM to override their as-built Canadian spec to give full lights control like the US spec'd vehicles have where you can turn the headlights and DRL off completely, or run just in the park mode.
That said....
There is companies here in the US that are able to custom write BCM programming to solve this.
Here is one of them - BCM (Global-A) – Custom Calibration Engineering
Everything they can customize - BCM settings – Custom Calibration Engineering
The tool you need to install - 2014-2020* AutoSync-G2 – BT DieselWorks
    tblt44
    tblt44
  • Who's Online   6 Members, 1 Anonymous, 640 Guests (See full list)
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
