I HAVE A 2004 TAHOE 4.8 ENGINE WHEN DRIVING IN 2 HIGH  IT WILL GO INTO  NEUTRAL COASTED OVER TO THE SIDE OF THE ROAD OPEN DOOR COULD HEAR A LITTLE NOISE NOT LOUD GRINDING MORE LIKE A LITE GRINDING NOISE COMING FROM TRANSFER CASE I BELIEVE HOOKED UP MY FRIENDS SCANNER TURNED TRUCK OFF PUT IN PARK START TRUCK PUT IN 2 HIGH TEST DROVE WITH SCANNER TO DUPLICATE PROBLEM NO CODES ON DASH OR SCANNER   ENCODER RING OR ENCODER MOTOR  ?  TRANSMISSIOM IS FINE IF I DOWN SHIFT 1 GEAR DOWN IT WILL ALSO GO INTO FREE WHEEL OR NEUTRAL ANY HELP THANKS MARK KULAGA
Probably a broken shift fork in the case, not a particularly hard job but easier with the case removed. check the encoder first to make sure, remove the motor and manually shift it into 4H and take it for a ride
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
