38 minutes ago, Atlas said:
26.3 is the latest iOS.
Try updating?
Already did, that’s the problem
Did you back up your phone before you installed the update?  Maybe you can restore your phone to a back up that you have before the 26.3 was installed.
I’ve never needed to before
Never had a problem before
Some apps are unusable
This one is almost there
Do you sync your iPhone with iTunes?  There could be a back up on that computer if you do.
Is there anything (data, photos, etc) on your iPhone that you cannot afford to lose if you did a factory reset on your phone?  I'm just asking as that will be a question from the Genius Bar folks if you go to the Apple Store.  You could "try" backing up your phone, then do a reset, then reload your data from the back up.
Check this link for what some people are experiencing and what they are doing to fix it:  https://discussions.apple.com/thread/256138930?sortBy=rank
Good Luck Stan.
Good Luck Stan.
Thank you
Not on a phone, but FWIW the browser on my iPad has been buggy since the iOS 26 update.  It’s still working but at least a couple times a day it will freeze up and I’ll have to exit out of Safari and restart it.  Was hoping the recent update was going to fix it, but still the same.  It’s a shame, it worked perfect before this.
My iPhone 3 is working fine with my apps. I’ve tried everything short of a factory reset on the 13 mini. I did learn some things on cleaning up back ground issues that effected my phones that made my old iPhone work better. I believe my issue stands with the latest update. Otherwise id already gone with a factory reset.
Almost all my apps are affected currently. Luckily my old iPhone is working flawlessly. They’re paired through Wi-Fi. It’s actually a iPhone SE. I thought it was going to be unsupported the only reason I went to the 13. It just received and update. It’s smaller than the 13 mini. I actually prefer smaller iPhones. I can wait it out for a fix. Otherwise I’ll put the SIM card in the old phone and do a reset on the 13.
Apple store wasn't able to help you?
If you have everything that is on the 13 on the iPhone SE, then if I were you, I would bite the bullet and do the reset.  But that is me.  You do you.  👍
According to my research it’s a known issue. I figured they will issue a fix soon. I’m assuming a reset will leave the latest update still activated after the restart. And reinfect. And my old iPhone is operating fine. The only thing  missing is the flashlight.
Edited by KARNUT
Well an update has begun. Fingers crossed
    250.3k
    chfkief
    chfkief
  • Who's Online   4 Members, 0 Anonymous, 1,490 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
