Is any one able to provide me a part of the bose amp wire harness?  I cracked a connector.  I have a 2022 1500 LTD Pre Refresh.  Or even pinout or wiring diagram.
Edited by Daniel Formichelli
you might find it on gmupfitter.com, otherwise I suggest a subscription to alldata.com, it has wiring diagrams, connector pinouts, and p/n's for the connector shell and pins.  After getting that p/n, I would find/cross match it to the connector on a site like mouser.com
Or hit a junkyard for the connector (somewhat unlikley given the truck's year).
alldata should still be running specials right now, up to 30% off (discount depends on length of subscription).
This is a combination of posts elsewhere in this forum that I used. Granted, I have 2021, but maybe the pre-refresh 22 is the same:
BOSE Amplifier
from the amplifier behind the rear seat on the wall:
Harness #1 = 16 pin
pin 4 = Left rear door speaker (+) green
pin 5 = Right rear door speaker (+) white
pin 6 = Left corner dash speaker (+) blue/violet
pin 7 = Right corner dash speaker (+) brown/black
pin 12 = Left rear door speaker (-) green/black
pin 13 = Right rear door speaker (-) blue/black
pin 14 = Left corner dash speaker (-) blue/brown)
pin 15 = Right Corner dash speaker (-) white/yellow
Harness #2 = 8 pin
pin 1 = Constant 12v power = RED/Yellow
pin 2 = Left Front door speaker (+) blue
pin 3 = Right Front door speaker (+) yellow
pin 4 = Center Console Subwoofer (+) Blue/GRAY
pin 5 = Chassis GROUND
pin 6 = Left front door speaker (-)
pin 7 = Right Front door speaker (-) = Yellow/Black
pin 8 = Center Console Subwoofer (-) = Green/Black
Harness #3 = 16 pin
all for data so do not mess with it. you can use this color code as a reference
pin 7 = gray
pin 8 = white/black
pin 13 = blue/yellow
pin 14 = blue/white
1480ElecticalComponentandInesHarnessConnectorEndView.thumb.webp.384367dd2dcd1b3c55e26cf8b3af7dbc.webp
    StewC
    StewC
  • Who's Online   6 Members, 1 Anonymous, 697 Guests (See full list)
