I've had an account in the gm trucks fourm for a couple of years now since I purchased my truck back in 22 but never posted in here. Glad to come here for advice or help troubleshooting my 17 Sierra Denali.
  • 3 weeks later...
On 5/6/2026 at 8:52 AM, slj2008 said:
Welcome - Good looking truck
Thank you!
On 5/6/2026 at 7:04 PM, txab said:
Welcome! :thumbs:
Thanks!
Very nice truck! I'm from Corpus Christi but been stationed in VA for years.
    zibzer2
    zibzer2
  • Who's Online   5 Members, 1 Anonymous, 805 Guests (See full list)
