Fungui1972 Posted May 11 Posted May 11 Hi, I just got a 2026 Sierra Elevation and while it has a button to roll all windows down at try same time and individual buttons doing the same, the passenger window is the ONLY window that will NOT roll up automatically like the other 3!!!! Is this normal for you all as well?
Jay P Posted May 11 Posted May 11 Try this. Programming may be necessary if the vehicle battery has been disconnected or discharged. If the window is unable to express-up, program each express-close window: Close all doors. Turn the ignition on or to ACC/ACCESSORY. Partially open the window to be programmed. Then close it and continue to pull the switch briefly after the window has fully closed. Open the window and continue to press the switch briefly after the window has fully opened.
newdude Posted May 11 Posted May 11 (edited) 3 hours ago, Fungui1972 said: Hi, I just got a 2026 Sierra Elevation and while it has a button to roll all windows down at try same time and individual buttons doing the same, the passenger window is the ONLY window that will NOT roll up automatically like the other 3!!!! Is this normal for you all as well? It won't. Only the driver's window is express up AND down on Elevation. The other 3 will express down but won't express up. You need to get to higher trims (Denali, High Country) to get passenger front up and down express. Those still will only have express down on the rears. Edited May 11 by newdude
Register a new accountSign in
