3 hours ago, KARNUT said:
I’ve had two vehicles use oil from new.
Yep, it happens, but...
The test subject under discussion used none for 20K miles THEN started using.
You tell me, what changed?
2 minutes ago, Atlas said:
That's some wild projection! The mental gymnastics in your posts are making me laugh. Do you need a hug?
He needs a...
 :idiot:
There isn't an intelligent discussion to have once we throw away facts, truth, reason, rules and reality. He didn't want an answer. He want's to be entertained. Disengage Number One.
He needs a...
 :idiot:
GM is the culprit. Drive style matters not. Hopefully the new 6.7 is back to normal : little to no oil consumption.
He needs a...
 :idiot:
I’ve never experienced that phenomenon. I’ve put super chargers on several GM engines the added pressure didn’t make them use oil. Most of my trucks (all brands) were tuned. Raising the max RPMs and shift points. No oil usage. I would change gears for more cruising RPMs. I beat them hard. They idled all day so my crew guys could cool off. No oil usage. My company paid for my trucks and gas. One of the perks of a family business. I worked hard I earned it. As I always say I can only give my and company’s experience. By the way it wasn’t just me. It was many.
Oh but were engineers we know better. What a joke.
Like you my experience with all my vehicles is that drive style ays no part in the oil consumption.
I don’t doubt their experience as such. I never treated my equipment as delicate flowers. They all were used as tools. They had to perform. They were also entertainment. We sometimes would race on pipeline roads. My dad too. You don’t have to do much to them now days. They haul ass. I still haven’t experienced an oil user. That doesn’t mean it doesn’t happen. If it did we would do a tear down to find out why. Well our shop guys would. It’s been awhile for me.
He needs a...
 :idiot:
Run!
8 hours ago, Another JR said:
Because it has never used much oil, I haven’t monitored it closely enough to know for sure. However, the measured drop on my latest longer interval after our road trip of 4500 miles (nearly 0.6 quarts) was roughly proportional to the drop in previous 3750 miles intervals (a little less than 0.5 quarts), which would imply the drop is steady.
The reason I asked that has to do with what I have observed over the years in various gas or diesel engines where upon the initial oil change the level depending on the engine seems to remain very good with little in the way of usage and not having added any oil so far but at some point that changes and can change fairly drastic on some engines where now the level has dropped a long ways down although still within the safe range and its time to add oil. Add the oil so its now back to full like it was at the beginning with the new oil but the time in operating hours now before having to add again is cut quite a bit shorter. I've chalked it up to the oil additives are being used up and perhaps some oil sheer as well. Some of these examples are farm tractors or combines etc that see a fairly similar load all the time and each year and each oil change shows up a very similar tracking, as the oil gets the hours on it, it starts to use more oil by a fair margin. I suppose it really doesn't come as a surprise that engines prefer new clean oil vs that same oil on the other end of the oil change interval.
My LZ0 is burning a little bit during break-in, but they come with an extra quart in the sump for exactly this reason.
Had a weird one...a 2.8 diesel in a Colorado. Didn't burn anything of concern until I towed a car on a trailer across the country. Was battling headwinds and mountain passes all day and it consumed almost an entire quart. I just about fell over. Refilled it, burned a little on the leg home, and then the next OCI, back to almost nothing.
The L9 in our motorhome burned oil on break-in but has stopped. It's got 35k now, some people say that's not broken in on a Cummins, but I think the rings are fully seated. It spends a lot of time pulling a vehicle on a trailer on mountain passes with the throttle buried. Good little engine it is, even though it's slowww.
Had an LLY Duramax in the previous rig but it was used, and it did consume some even with 50k on it.
I keep my rigs filled to the "full" mark on the dipstick. When they drop below that, i consider that refill territory.
Then you haven't any relevant input for those that have had that experience, right?
Sounds like relevant experience. Also in line with the OEM Engineers of both GM and Ford. Ford makes note in their oil consumption test that they will use oil for the first 10 K and not to do a consumption test before that point.
https://static.nhtsa.gov/odi/tsbs/2019/MC-10169811-0001.pdf
GM defines things like aggressive and towing. Break in, excessive idle, ect.
https://dot.report/bulletins/11007091
On 5/27/2026 at 2:05 PM, riddler said:
Thanks for the info. No leaks using about a qt every 3k. I have 31k on it been burning oil since 20k. I will put Valvoline in it my next oil change.
Oil consumption free for 20K miles then BOOM, it starts?
And YOUR driving habits, environment, fluid maintenance had nothing to do with that?
Some GM Engineer come into your yard at 20K and sabotage it?
But your going to use Valvoline to free/clean the rings?
Those are YOUR words I quoted.
GM gave you an oil tight motor. Your inputs fouled them. If you believe those rings can be freed/cleaned by use of Valvoline's Restore and Protect then their fouling could have been PREVENTED GENIUS!
:banghead:
If you don't believe it will work and your going to try it anyway.....WHY?
:idiot:
Edited by Grumpy Bear
So you rather people think everyone has an oil burning problem? There’s not many people who have had more experience with multiple vehicles than I have. Through my hobbies and my business. If you have a vehicle that uses oil that’s not normal. Most people don’t have an oil burning problem even going by the manufacturer’s recommendations. Your service intervals aren’t normal. You’re what is called an outlier. Most people don’t have time or the inclination to do as you do. I’m not saying to you that you have no input. You seem to have an issue with a person who has a different experience than you. My experiences are real. Maybe it all comes down to using Amsoil. Even during my extended days. If you don’t like it block me once again. I don’t need your approval.
Edited by KARNUT
GM is having a problem with the 6.2. It started around 2020. It’s been reported even in the 2026 models. Driving style has little to do with the failure. The mileage varies. The service duty varies. The failure event varies. So is it possible it’s happening with this engine with little driver input? Duh!
:banghead:
:idiot:
Stupid is as stupid does. Go away your irrelevent just like driving habits to oil consumption.
Humpy Bear, aka GM fanboy. Block us both please. Your irrelevant. @Grumpy Bear
    • That's interesting, I assume that would add to the cost of the oil but also I was forgetting to bring up the issue of the low tension rings allowing more oil past which in turn forces the cats to have more oil additives pass through them that wouldn't otherwise so they are creating that problem and of course its all in the name of fuel economy. Mind you the other issue would be the lack of additives that fight the formation of carbon within the piston ring grooves which turn the engine into an oil burner and with in this GM forums case is your average off the shelf Dexos licensed oil, meanwhile the other off the shelf oil being Valvoline's R&P isn't licensed and the only one that is which is that certain Mobil oil that came out recently ( its not even being marketed in Canada ) and only a fraction of vehicle owners are going to be using it out of all the other oils on the shelf or the quickie lube bay that meet the Dexos spec by way of actual licensing.    Also I suspect that its an easy excuse to pool the non turbo DI engines in with the turbo DI engines and design the oil to not have LSPI issues in the most demanding engines and short change the naturally aspirated DI by not offering a higher concentration of additive package they could handle and still not be at risk of LSPI.    I wonder if Amsoil flipped the switch just lately and did whatever packaging designation at the same time as I wonder what oil formulation I would have bought in May, of course I don't know when it was packaged at the factory vs how long it was in storage at the Edmonton warehouse. I know its been said at least in the past that the big players switch over to a reformulated oil but the packaging has not changed until they make that move as well so there is that cross over time where its a new formulation in a predated formula marked package.
    • Hmm. A real reason to not just use the odometer to determine OCI?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
