Is there any truth to the below:
2026 Silverado owners found a reliability top priority: the 8th VIN digit "E" confirms the 5.3L V8 lacks DFM hardware. This factory delete solves the notorious lifter failure issue plaguing Chevy trucks since 2019?
Can anyone tell which trim are these trucks and where can I find a new 2026 with this fix?
No engine digit "E" for 2019-2026.  Stop reading slop online
All 2026 V8s have functioning DFM.  Hardware and software.  5.3 and 6.2.  The L84 5.3 has "D" as the 8th digit of the VIN, the L87 6.2 has "L" as the 8th digit of the VIN.
If you want a factory DFM disabled 2019-2026, you'd have to find a used 2021 or 2022 chip shortage truck.  The vehicle build data will have a specific RPO code indicating its a factory disabled truck.  RPO code YK9 and only with the L84 5.3 engine.  These still have the hardware installed but are NOT functioning due to the COVID chip shortages that were ongoing.
Thanks New Dude'
Just now, PUSSLEGUT said:
Thanks New Dude'
I got my information from Torque News
2026 Silverado VIN Hack: Look for 8th Digit ‘E’ to Confirm the DFM-Free 5.3L V8 That Ends Lifter Failure
Can you tell me if a new gasser GMC 6.2L Denali or a 2026 5.3L Denali is safe to purchase? I have read a lot about engine failures and just want to be safe. What would you recommend? Plan on purchasing a new truck in the near future.
Thanks for your assistance,
John
John
That article is complete BS.
Get the 5.3 over the 6.2.  Or, wait for the new trucks.
That site even proves there st
26 minutes ago, PUSSLEGUT said:
He proves his stupidity even further here - 2026 Chevy Silverado Owner Scans VIN and Finds A ‘Holy Grail’ Discovery; He Says, “GM Officially Deleted DFM Because They Knew The Lifter Issues Were Killing The Brand”
The VIN in that article 1GCUKGED7TZ191335.  The 8th digit is literally a "D".  1GCUKGED7TZ191335
1st - 1
2nd - G
3rd - C
4th - U
5th - K
5th - G
7th - E
8th - D
D is for the L84 5.3 with DFM.  The build sheet of his "smoking gun" VIN shows L84 5.3 with DFM.  What a r'tard that person is.  He even sites an AI SLOP video on YouTube as a source.
Edited by newdude
1st - 1
2nd - G
3rd - C
4th - U
5th - K
5th - G
7th - E
8th - D
Thank you very much for this info. I will start looking for a 5.3L. I have viewed several Youtube video and get so confuse. You are the first person to give good advice.
Thanks again,
John
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
