2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck
I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one
#1   Since we have owned our truck purchased new it has this strange noise after using the remote start function
you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .
There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of
#2  You can only hear this if you are standing outside of the truck and near the truck
you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally
#3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again
I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it .
Now its back in the Dealership left it overnight so they could possibly hear the problem .
They said they tried and nothing happened . Well they did not know what they were listening for .
I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership
Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like
Really  would like to know if this is anormal sound
Thank You Fellas !!
Oil pump noise was discussed before.  I will try to remember to record a remote start later this morning.
Thanks JR that would be great if you could do that !!!
Do you have a link to where this was discussed before ? I cant seem to find it
Thank You Again !
Thank You Again !
My plans changed today so I haven’t had a chance to record a start yet.
This is one of the threads I recall, but you were involved so maybe you already reviewed this one:
Thank you JR !
Whenever you have time to record your tucks starting it will be appreciated !!
I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
I usually upload to youtube then paste the link here. I haven't done it here but it worked on other forums.
Thank you JR ! Here's hoping you can post the video with sound
JR ! I just got the truck back from the Dealership today . The technician did a cold remote start on the truck this morning and it made the noise . It was determined that it was a starter issue and replaced it under warranty . Of course   it did not make the sound after a new starter was put in because the truck was not cold . We will we see what happens tomorrow morning when I start the truck cold  . Keep tuned !
Oh I found a video on YouTube of a cold start and it did the same thing your truck and mine do ,
I will see if I can find it and post it up
Here we go JR and others this is exactly what my truck does
  • Confused 1
Mine makes the same noise on cold starts. I'm pretty sensitive to weird noises (check out my post history 😁), but I assumed this was just normal.
Thanks Buck Wallace ! The more owners that tell me they are getting the same noise the more comfortable I will be with it !
Next time I start mine up, Ill listen but I dont think I have ever heard that noise before.
Mine has no such noise when it starts up first thing in the morning.
    B07
    B07
  • Who's Online   1 Member, 1 Anonymous, 871 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
