IF it will reduce the effort in polishing, I am willing to pay the price. The salt in the winter is HARD on a shine and takes a lot of "elbow grease" to get wheels back into shape.
Just wondering exactly what it is and if it would help.
Thanks!
    bellssn690
    bellssn690
  • Who's Online   5 Members, 1 Anonymous, 1,102 Guests (See full list)
