LOL!
pacodiablo
Dear Beloved,
It is a privileged to hear from God and it gives me
joy to relate my testimony to you haven received
instruction from God through divine revelation.
And I have the pleasure to share my testimony with
you, having seen your contact from the Internet. I am
David Evans, the legal adviser to late Mr. John Duke
couple that lived in my Country Nigeria for 32 years
before they both died in the plane crash late last
year. These couples were good Christians, they so
dedicated to God but they had no child till they died. throughout their stay in my country, they acquired a lot of properties like lands, house properties, etc.
As their legal adviser, before their death, the
husband Mr. John Duke instructed me to write his WILL.
Because they had no child, they dedicated their wealth
to God. According to the WILL, the properties have to
be sold and the money be given out to a ministry for
the work of God. As their legal adviser, all the
documents for the properties were in my care. He gave
me the authority to sell the properties and give out
the fund to the Ministries for the work of God.
In short, after their death, I sold all the properties
as instructed and I was able to realized $15.5million US dollars). Instead of giving the fund out for the work of God as instructed by the owner before his death, I converted the fund to myself with the intention of investing the fund abroad for my personal use. I was afraid of putting the fund in the Bank, because I have to give account to the bank on how I got the money. I then packaged the fund in a trunk boxes and deposited the trunk boxes with a Finance & security company in
Europe.
I registered the content of the trunk boxes as Gold
Bars. Now, the security company believes that what I
deposited with them was Gold Bars.
I had encounter with Christ when Pastor Paul was
preaching the word of God on television. After hearing
the word of God, I gave my life to Christ and became a
born again Christian. As a born again Christian, I
started reading my bible and one day, the Lord opened
my eyes and I discovered that the only way I could
have peace in my life is to do what is lawful and
right by giving out the fund as instructed for the
work of God by the owner before his death.
I have asked God for forgiveness and I know that God
have forgiven me. But I have to do what is lawful and
right in the sight of God by giving out the fund to
the chosen ministry for the purpose of God's work as
instructed by the owner before his death.
After my fasting and prayers, I asked God to make his
choice and direct me to a honest Christian or the
chosen ministry that deserves this fund by his Grace.
I then came across your address on the Internet as I
was browsing through a Christian site, so this is how
I got your contact information, and I then decided to
contact you for the fund to be used wisely for things
that will glorify the name of God.
I have notified the Security Company where I deposited
the trunk boxes that contained the fund, that somebody
some one is coming to claim the trunk boxes on my
behalf of which they accepted.
So if you know that you will use this fund honestly
for things that will glorify God's name, then do
urgently contact me back first through this my
private email address only
[email protected]
and the details will be given to you on how you will
be able to receive the fund in your country through
the security company.
PLEASE REPLY ME IN MY PRIVATE AND SECURED E-MAIL BOX [email protected]
You should also forward to me your telephone and fax
number for easy communication and to fax you the
documents concerning the trunk boxes.
Your prompt response will be highly appreciated.
Yours in Christ.
Barrister DAVID EVANS.
[email protected]
This guy emailed the wrong person, I'm an atheist. :cool:
Even if I was a Christian, that has got to be the worst story any scammer has ever sent me.
    • First off pay close attention to what Newdude pasted as he is a GM tech !.    I have a couple of questions which might cross off some questions others on this forum would be wondering about as well. So when was the engine oil changed prior to this trip, was it almost brand new oil or did it already have a fair bit of use on it before you started the trip.   Did you check the oil level on flat ground and was it at the full mark just before leaving on this trip which I gather from google map is about 700 miles or so. Why I ask and this is not the first time in history that has happened, that either a dealer or some other shop changed the oil on the vehicle and the vehicle left the shop and the owner ( you ) assumed the engine oil was full but in reality the person who changed the oil simply did not put enough oil into the engine .. it happens !. Also that a shop put the wrong viscosity oil in and an engine was not happy with that thinner viscosity and oil got past the rings at a higher rate than the proper viscosity. Not to mention if there was any leaking out of a drain plug or the filter gasket etc.
    • You could, although in the end it really doesn't make much difference what comes out in exact terms since it comes down to putting enough back in so that there is enough volume so that something flows back out once the trans is up to temp for the check procedure. I presume your putting a pan on that has a drain plug but its probably the same pan mold/size as at least a while back no extra volume pan was made for the gas truck version due to the exhaust cross over pipe issue. All I can say as per volume I put back in and this was based on changing out the filter as some is trapped in it that does not come out until its removed because of the way its made inside and my truck had sat over night with the trans having been hot when shut down and dripping internally before I pulled the pan. I went off of what the trans shop suggested as a minimum volume he found worked which was 9 1/2 quarts and I had enough flow out of the stand pipe that I knew I was right on the money once it slowed to a dribble and never wasted hardly any oil but it would be totally fine to throw in a full 10 quarts too. I guess personally I wouldn't ruin a perfectly good pan by drilling a hole in it, not with the cost of replacement pans up here or the dorman one anyway with the drain was 500.00 when I priced one out a while back, totally stupid.    I might not have said before but this trans oil type really expands with heat and I think its been said on this forum and the trans shop said the same so I wanted to try and hit the lower temp of the range vs at the top or go shooting above it as that would allow more oil to flow out which wouldn't be ideal.
    • Since I am going to be replacing the pan, I am just going to drill a hole in the original to drain it so I will be able to catch the fluid easier and measure how much I took out.
