does tire size affect performance?
I have 235/70R15's on my 98' Jimmy, what affect on performance, handling, and braking will I see if i switch to 235/75R15's
absolutely. the taller the tire the more sidewall flex, affecting your handling. Plus, let's say you have 3.42 gears and you go to a taller tire. it's like swapping to 3.23's or 3.08's depending on how tall you go. By the same token, put a shorter tire on and it's like going to a 3.55 or 3.73.(just examples)
tire size affects your overall ratio.
That is one of the best questions I've seen posted in a long time.
Interesting thread....wish I had the expertise to answer.
Jim
AND..................Your speedometer will be off & the ABS brakes might act a little weird too as they were designed for the factory size tire rotation...
So, I will burn more gas and jeoperdize my safety! I guess I will stick with my original tire size, thanks for the help.
