Transmission Cooler Line Tool
Does anyone know if you need a special tool to unhook the transmission cooler lines? If I need a special tool does anyone have the part number and know where I can get it?
Thanks for the time,
Bob
What year is your truck? :wtf:
If it does have the snap together lines you should be able to get the tool from your local parts store,I know that Auto Zone and Advance Auto has them in my neck of th woods,sorry but I dont know the part # :chevy:
:confused:  :crackup:  :crackup:
Here's everything you need to know:
Trans cooler LINES DIY thread
PICKS, part# SG3ASHG is the best one for the job... It has a curled flattened end that is offset, works perfect. Or just bend another pick or screwdriver..
Good luck with this  :puke:  of a job...
Let me know if you need any more info. This job is still fresh in my mind, as the wounds are still healing....
Uh oh, don't sugar coat it, and say it's anything other than horrible... I'm just now able to sleep again after the wretched install, and that was 3 months ago for mine! LOL
Good luck on the install man, When the dealer wanted to charge me 4 hours of labor to install that junk, I thought they were crazy. I don't think they're too crazy now... Whew.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
