Driver 1, Driver 2 Settings
You know how when you start a newer GM, it says "Driver 1" or "Driver 2" where the odometer is?
ON our new 2004 Yukon, it once said Driver 1 and now it says Driver 2. And I know you can do some prgramming so that Driver 1 has the seats, outside mirrors and radio presets programmed to his/her liking and you can program different settings for Driver 2.
It is not an SLT or LT so it does not have the Memory 1/2 buttons on the driver's door so......
How do I do this?
It's all controlled through the Driver Information Center (DIC). To use this feature fully you must have steering wheel audio controls and electric seat positioning controls.
I have a 2004 Yukon also, and I'm not sure about the different programs. However, the driver 1 or driver 2 is related to which remote you use to open the door. If you use one remote one day, and another the next, that's why it's changing. It's labeled on the remotes that I got from the dealer.
Hope it helps.
J
I used each remote to start it and it said "Driver 2" for each remote/key used.
But I did not unlock the doors with each key as the car was already unlocked, so maybe you have to actually use the remote to unlock the doors.
But from what y'all are telling me, I can't change settings for each driver anyways?
well some you can't, but it will change your radio presets. Yes you have to press the unlock on the remote to get to that setting.
You can set things like radio presets, mirror locations, mirror curb feature, a/c controls, etc. It is some neat stuff. It will even remember the CD track you were listening to when you shut off the truck, even if you don't use your remote until like a week later.
I believe Driver 1 versus Driver 2 will come up based on what key is put in the ignition not what remote is used to unlock the door. Although, that is likely to still be the same. You will need steering wheel mounted controls to change settings from what they are now.
the keys aren't coded or anything to tell the computer which driver it is. That is why the fobs are numbered 1 and 2 and when you press unlock on the particular fob it automatically uses that drivers settings. Like said before. Even if you don't have the steering wheel controls, it still changes the radio presets and to what you were listening to last. And with auto climate control returns the ac to last setting.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
