36k service suggestions
I got 37k now, going by the manual, all you do is change the oil and filter. Any other suggestions ?
Trans flush and filter is not a bad idea. New air and fuel filters along with the normal oil change lube job and tire rotation. If you go to the dealership for the service ask their opinion but do not let them sell you services you don't need. Remember it's your call, the service writers are paid to get as much out of you as they can. They can actually get in trouble if their numbers are down.
