FS:350 Internal Engine Parts
Internal engine parts for a 350, all parts are New In Box,,,
TRW Pistons L2441F.030 over
Wolverine Cam WG1170 w/ lock plate
Wolverine True Roller Timing Set WG701
Johnson Hyd Lifters
Sealed Power Chromemoly Push Rods PR3212R
Melling Oil Pump M55HV w/ PU Tube
Fed-Mog Bearings Mains 4663M, Rods 2555CP, Cam 1235M all STD.
Felpro gaskets
$500.00 takes all!
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
