G80 Rear Diff Clicks and Chirps
I have noticed a somewhat random clicking sound coming from the rear end of my 00 Sierra SLE 4X. If I really stomp on it from a dead stop, I get a few creaking-sounding clicks, and sometimes even a bird-like chirping that increases with increasing speed--this sounds absolutely horrible. I also get random clicking noises while just driving around town--they really sound like the frame creaking, but its definitely coming from the rear-end (my wife drove my goofy butt around whilst I hung off the tailgate).
SO, this morning I drained the diff and pulled the cover to take a peek. Ring, pinion, spider gears---all visible parts showed no sign of wear. Didn't jack up rear, and locking side of the cage was on the opposite side. Old gear oil had nothing but tiny flecks of metal, magnet on cover had very few tiny shavings, and residual oil in bottom if pumpkin had nothing but tiny flecks of metal... No signs of failure or abnormal wear.
I've heard that these locking rear ends start to make clicks and chirps when they start to go bad. Plan to take this in ASAP, but would appreciate any input from you folks...
Thanks
The gov lock in a a 8.5 inch axle is not noted for it durabilty or longivity. YOu might try a fresh fluid change with some limited slip additive. If the noises are coming from there it is likely from the clutch pack in it.
Did you drop the driveshaft and check the u-joints?
A dry joint may not be noticed without removing the driveshaft and articulating the joints by hand.
Seen a ton of u-joints make thiis exact same noise.
Hope this helps.
Hope this helps.
Yes a good possibility. Sometimes I have found that you can insert a finger in between the u joint yokes and rock/twist drive shaft back a forth (engine of in neutral with park brake on) and feel for slop or wear in joints. If you can feel it, it is worn for sure and needs servicing.
nope, didn't drop the drive shaft, but appreciate the input. I wrenched a bit on the shaft with the rear end jacked up and could not discern any play in the U-joints, but realize that the method I used wasn't the best...
SNOMAN--after taking a look at everything I refilled with new Mobil-1 synthetic 75W-90 and then took it out to put it through its paces... Diagnosis=same ol stuff... I thought the 99 and newer rigs didn't need the additive, especially if you go with synthetic gear oil.
I guess I forgot to mention in my first post that I had inspected the diff, replaced the gear oil, and then took the truck out to see if it made the same noises (it did).
I'm betting on something just starting to go south in the differential, but it would be pleasant if its just a u-joint.
Thanks, Gentlemen.
Thanks, Gentlemen.
I know that a additive is not required but when plates are warn it can help. Does squeak change with throttle presuure and change with striaght or turns?
Snoman--10-4 on the additive. I was confused as to whether or not it was "required'...
The only way I can reliably get the noise to occur is when I firewall it from a dead stop, and even then it only happens about 1/3 of the time. Otherwise, I get random clicks while driving around town, whether going straight or around a turn or...
When I get the darn noise to occur, it starts with a few random clicks that don't seem to match revolutions or engine speed, then breaks into a bird-like chirping that matches revolutions and speed until I let off the pedal. I can only get it to chirp with a jackrabbit start, have never heard the chirp whilst driving around town.
On a separate note, as I noted above I can now only get the thing to make nasty noises about 1/3 of the time when I firewall it from a dead stop now that I have changed out the gear oil. B4 I changed the fluids, I could get it to go about 9/10 of the time... So the diff fluid change helped, but didn't cure the noise.
I'll definitely ask the mechanic to drop the drive shaft and check out the u-joints B4 tearing into the differential. Would be very sweet if that is all that is wrong.
Does it sound like a gernade going off :thumbs: Mine has done this since new if the locker kicks in (especially on wet pavment/grass). It really scares passengers or cars behind me but I must say it kicks in and works fine seems like the noise is the locker engaging. I have near 48K miles on mine and it has worked great. Its not the U-Joints (just changed em and it still makes the noise).
That gov loc in a 8.5 is a grenade waiting to go off! If you ever replace one, do not rebuild it, replace it with a different type completely.
Snoman--You were talking to RyanbabZ71, right???
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
