Fuel pressure regulator question
I've been having a hot start problem with my truck and tonight for kicks I pulled the vacuum line off the fuel pressure regulator and fuel poured out of the vacuum line. I am not an expert on this system,but I don't think this is good. If the regulator is in fact bad, can I pop the old one out of the fuel rail and replace? My truck is a 99 2wd 4.8L. Thanks!!
You are correct. If there is fuel in the vacuum line the regulator is bad. Just replace with a new one and you should be good to go.
Well, after cleaning my K&N Drop in Filter and re-oiling it, cleaning the throttle body with some GM Top Engine Cleaner, and cleaning the MAF Sensor off the air box with some good Electrical cleaner spray, I started having the same problem.
I since pulled the filter and replaced it with a regular paper one, thinking some oil got on the MAF sensor and cleaned it up again with the Elec. Cleaner.
I'm still having the same problem. Since I still have a warranty on this beast, I'm taking her down to the stealer to have them work on it... no sense in me paying for the part if they will fix it for free....
The more and more I read about it, it has to be the regulator....
My one question is, when your's went bad, did you hear any noises when you turned the key to "on" but didn't start it when it was cold?
When I did it this morning, after the usual fuel pump HUMM, I heard something like slipping gears up in front of me coming from the engine bay (driver side).
I know the regulator is up there, on the driver side valve cover.... but would that make that kind of noise?
Another way to check if you fuel pressure regulator is going bad is that if your truck does not start on the first try, hold the accelator to the floor. If the fuel pressure regulator is indeed bad, it should start with the pedal to the floor! :banghead:
Thats what its doing, once she gets going its fine..
Now... the million dollar question.... I have to haul some wood up to the camp this weekend, about 60 miles away
Will I be able to do this, or should I not take a chance with it.......
Its been doing this for about a week or so....
What are the next stages after the "hard hot start"... or does it just stop sending fuel all together (not good)....
SteveCZ, no I didn't have any strange noises,but when trying to start hot, the truck would struggle to start then run but almost stall and then hunt until it found idle. My truck as well would run fine out on the road. The sure fire test is to pull the vacuum line off the regulator and was my case,fuel poured out of the vacuum line which is a dead giveaway that the regulator is bad. It's a pricey little part,I payed $67 for mine GM p/n 17113678. Hope this helps :banghead:
If you have the $70 for the part and 10 minutes I would just get the part and replace it. 2 screws, wire connector, vacuum line and you are done! :banghead:
    • Most online suppliers and Amazon. All have noted "not for use with Bose speakers".
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
