CD/Radio Backlights
Two backlights on my '99 Silverado stock cd player have burnt out at seperate times; the light for the #1/#4 preset stations, and the light for the #3/#6 presets.
Does anybody know if these can be replaced? If so, how would you go about getting into them??
THANKS!!!
When my cd player went out on my 02 (two weeks after I bought it) I took it in and they said that they would have to replace the entire cd/radio and that it would have to be ordered so for about three or four days my truck did not have a radio. My guess would be the dealership would just replace the entire cd/radio.
I've replaced them on a 95 Tahoe and 96 Burb. I got them at Radio Shack. If you take the radio apart, replace "ALL" of them when your in there.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
