LET IT SNOW LET IT SNOW!!
pacodiablo
The truck was clean
THat is snow just started less than an hr ago.  We got allthat in about 35-50 min
We got nuttin either...problem is that we depend on a good amont of snow in eastern upstate New York to fill the reservoirs and water supply when it melts in the spring....we are really in the middle of a draught funny as that sounds..
I live in northern WV.  The various weather services are calling for awywhere from 3" to 12" starting tomorrow afternoon.  We'll see.  I don't mind snow but I hate freezing rain and ice  :D  .   So far we've only had about 5" total in two separate snowfalls.
Wednesday night it started snowing here in South Carolina.  First time in this area since January 2000.  We got a total of 4-5 inches here.  Enough for all the kids, and certain dads, to have a blast out in it.  Here's our snowman that me and my son built.  He's pretty much melted away now.
central IL has about 1inch.  WaHOOOOO!!!  There are even places that are slippery.  Normally, I wouldn't think this is great, but this is the first snow and slick stuff my truck has ever seen.  And I've never experienced it with rear wheel drive or 4 wheel drive.
we got a few inches (3-4).  Snowed on and off.  Me and my gf were coming back from getting gas.  Found a nice school parking lot was gonna go do some donuts but 2 ^%#^ tahoes were already there doing some.  Couldnt hit the other lot cause to many cops pass by.  I did have my truck sideways a few times (on purpose) this stuff is so much fun.
The bfgs provide alot of traction which kinda sucks cause the fstones would break the rear loose so easy.
Thats a snowman?  I thought it was a Ford salesman....
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
