1999 Silverado Rear Brakes
Hi,
I'm new here, so please bear with me. I'm working on a friends 1999 Silverado extra cab 1500 short bed, 4.8 litre. The rear brakes are shot, they're worn down to the metal backing on the pads. The fronts are practically new and the truck only has @40,000 miles on it. Have you guys seen abnormal rear brake wear on these trucks? I'm going to replace pads, rotors and hardware. The calipers seem fine, the pistons compressed back into their bores easily. Slide pins were not frozen. I'll be using Raybestos PG stuff, any tips or suggestions? Thanks, Narti.
There's acutually a TSB about pre-mature rear brake wear...involves installing inner fenderwell mudflaps...I'll paste it here. Also, be sure to replace the rear parking brake shoes and clips,(they come together as a set from the dealer and I would imagine that aftermarket manufacturers offer them also), the original design retaining clip is prone to breakage, allowing the shoes to shift and rub on the drum part of the rear rotor, wiping out the e-brake shoes and rotor. The new shoes have a re-designed clip.
Another tip...If you reuse the caliper bolts (that bolt the caliper to the caliper bracket) it's a good idea to put some medium strength (blue) locktite on the threads, as the General actually recommends replacing them, but they can be re-used with a little blue insurance. Also, clean the sliders well and coat them with some good nickel-grade anti-sieze to help keep them from siezing up.
Here's that TSB...enjoy!
Brakes - Accelerated Right Rear Inner Brake Pad Wear
Bulletin No.: 00-05-23-005B
Date: May 27, 2003
TECHNICAL
Subject:
Right Rear Inner Brake Pad Wear (Install Rear Wheel Mud Flaps)
Models:
1999-2004 Chevrolet Silverado 1500 Series Pickup Models
1999-2004 GMC Sierra 1500 Series Pickup Models
Supercede:
This bulletin is being revised to change the content from Informational to Technical. Please discard Corporate Bulletin Number 00-05-23-005A (Section 05 - Brakes).
Condition
Some customers and dealers may comment on accelerated rear brake wear on some of the above listed vehicles. This condition occurs mainly on the right rear inboard brake pads and on vehicles that are exposed to extensive off-paved roads.
Correction
Install a mud flap forward of each rear wheel using the following procedure. Installation of these mud flaps and following the recommended off-road driving information provided in the vehicle's Owner's Manual should greatly reduce the possibility of accelerated rear brake component wear.
Important: Always work from outboard to inboard, drilling one hole at a time and securing with a fastener. Follow the sequence of the procedure. This will prevent distortion of the mud flap.
1. Raise the vehicle. Support the vehicle.
2. Locate the pickup box side panel rear brace.
3. Remove the existing outboard upper fastener on the brace.
4. Install the mud flap through the "V" of the brace. Install the previously removed fastener in the hole (2) of the mud flap to the brace. Do not tighten the fastener at this time.
5. Using the mud flap as a template, locate and mark the location of the hole (1) in the pickup box wheelhouse.
Important: After drilling the holes, apply the appropriate anti-corrosion primer. Refer to the GM Refinish Material Booklet # ,4901M-D (English) or # 4901-D-F (French) for additional information.
6. Center punch the marked location and drill a 6.35 mm (1/4 in) hole. Install the plastic retainer in the hole (1) of the mud flap.
7. Tighten fastener at the hole (2) location of the mud flap.
Tighten
Tighten the fastener to 25 N.m (18 lb ft).
8. For vehicles with short box, use the following procedure:
8.1. Push the mud flap to make contact with the rear side of the underbody cross sill and mark the location of the hole (3) of the mud flap.
8.2. Center punch the marked location and drill a 5.159 mm (13/64 in) hole.
8.3. Install the screw.
Tighten
Tighten the screw to 4 N.m (35 lb in).
8.4. Repeat the above steps for hole locations 4 and 6.
9. For vehicles with long box, use the following procedure:
9.1. Push the mud flap to make contact with the front side of the underbody cross sill and mark location of the hole (5) of the mud flap.
9.2. Center punch the marked location and drill a 5.159 mm (13/64 in) hole.
9.3. Install the screw.
Tighten
9.4. Repeat the above steps for hole location 6.
10. Repeat the above steps for the opposite side.
Parts Information
Parts are currently available from GMSPO.
