New to da forum
Hi everybody! I'd like to take this time to introduce myself. My name is Cory and I've been a Chevy/GM fan since I was young. I've owned 4 GMC work trucks from 1500 Z-71 4x4's to 2500HD 4x4's and loved everyone of them. I'm just about to buy my next and newest truck an 04 GMC 2500HD crew cab 4x4 this coming week (I can't wait). I'm so glad to have found a forum for GMC truck fans as I have already found a wealth of info on this site.
Keep up the good work!!!
thanks guys!
waiting to sign the papers tomorrow, then the lift in going to be installed ... ready for friday!
Will post before and after pics soon!
    • I have a 2026 base 1500 "WT" regular cab. How many speakers do I have If I want to upgrade? Is the audio amp separate from the radio/display unit? [I listen to classical and it gets a bit raspy at slightly higher volumes.  Don't need a sub etc.] Do I have two or 1 speakers in the doors? Thanks Bill  San Jose
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
