XP SP2 is out tonight!!!
5.3LSilverado01
yeah I got it...takes a crap load of time to put on there....the only thing I like about it so far is the pop up blocker.....you can still turn the fire wall off....but then you have a new icon in your task bar (stupid MS)....o well though....atleast my computer still works....as does all my software....I wonder what kinda of havoc this will make at work tommorow??
Yea thats what we were afraid of so we made sure auto update was off on the images before we pushed out the clean images to the machines and we wont let anyone dl SP2. We'll will let others be the guinea pigs.
So if you install this, do you really have to back up all of your files beforehand, or is like a "plug and-play" program? I'd hate to have to go in and un-compress EVERYTHING and back it all up before I can use any of it.
quick question:
if I'm running auto update, and I'm at, say 50%, and I get off the net, will it pick up where it left off when I get on the net again?
I'm running accelerated 56K here, a d/l that size will take a LOOOOOOOOOOOOOOOOONG time, I know I can't keep that connection stable for 18 hours straight.
whoops, I guess I'll oder the CD, since it's FREE!!!!
since it takes 4-6 weeks to get here, I bet they will have some of the bugs fixed by then, so all I'll have to do is get the lastest SP@ add-on's then, and won't have to go theough the "version 1.0" trials.......
of course watch tjhem have to release a 200 MB fix.......that's isn't availble on CD!
I have it on both my computers and so far everything this is good. The pop up blocker actually works!!!! and I havn't had any problems with accessing site, or using any programs.
My roomate is getting a conflict with his anti virus after he updated. I think he said it doesn't work now or something like that. He keeps getting a notification on his toolbar that he is open to virus attacks :lol: anyone else have this problem :thumbs:
You can get rid of the system tray icon by going to Control Panel>Security Center>then Under Firewall click on Recommendatins, in the pop up box check the box "I have a firewall solution that I'll monitor myself"
DO NOT INSTALL SP2!!!! It will break a ton of programs already installed on PCs. There are also two know bugs with it... SP2 should be out atleast 2 to 3 months before you install it... Let someone else beta test a SP...
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
