4L80E - No 4th gear - please help!
I need some help. I flushed out my trans and while it was a messy time consuming job it seemed to go alright. When I test drove the truck it was a little low on fluid because I flushed too much out. Anyway it was slipping in 4th so I put it in second and it seemed to work fine. I got some more fluid and filled it up but it is still slipping in 4th. In fact I don't think that I have forth gear at all but the rest seem to be working fine if I put it in third. It required quite a bit of a tug to get the pan out and a good solid push to put it back in. Do you think that I damaged something?
1. Does anyone know what I should be looking for when I open the trans up again?
2. If I undo the exhaust at the manifold will it let the exhaust drop enough to get the pan out without further damage? Does the heat shield on the passengers side of the trans need to be removed as well? Will the exhaust seal back up again when I tighten it back up or will I need new gaskets or something?
Thanks guys I could sure us some help. :thumbs::lol:
I got the heat sheild off with lots of cursing the punk engineer :lol::thumbs: who designed it, the shifter cable bracket that are both in the way and the recessed drain plug that leaves 2 quarts of fluid behind. All these could have designed for eaisier servicability. I understand the wedging it in and out routine... did you drive it long while it was slipping?
I did not drive too far with it slipping. I felt it right away and gave it a little tap and it revved up to about three grand. I immediately pulled it down to second gear and it seemed to drive fine. It does not feel like it is engaging fourth gear at all. I took it home and filled it up with about 3 litres of ATF and tried it again with the same result. When it shifts into fourth under easy throttle you can fell it slip. If I pull it down into third it seems to go fine.
Thanks
You may have run into the same problem my friend did. His truck wouldnt go into overdrive after a flush. It ended up beng a little solenoid that went bad. Not sure the exact designation of the noid. He replaced it and all was well. If you take the y-pipe loose at the manifolds it wll drop enough for you to get the pan off. Thats how I do it. Does your fluid smell burnt at all?
Look also at the shift solenoid connection. When I changed mine I accidentally unpluged it a bit removing the shift linkage. Mine slipped and was a "piece" until i repluged that back in. I think i may have broken the lil plastic lock piece as it seems to pop out a bit on occasion, but i just have to crawl under and fix it quick.
Hope this helps you out!
Scott
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
