Underbody Neons
I have a street glow underbody kit for my truck 2- 30" and 2-56" where would be
a good place to put them? My truck is a reg. cab 8ft bed. And were to stick the
transformer?
Any Suggestions?
  • 1 month later...
So keeping in mind I have never done a light kit, here are some suggestions:
Front - try to get this just under the frame horns as close as reasonable to the front air dam. Too low and you might bash the tube if you pull in too close to a curb.
Rear - this is a tough one. If you get the tube between the bumper and the spare tire, it might be a bit too high to light the ground as well (you would be able to see the tube if you don't have a lowered suspension). Two shorter tubes might have worked better - running the length of the rear rocker panel just behind the wheel.
Sides - you might need to create some 90 degree brackets that bolt to various holes under the body just inside the rockers. This would be easiest if you already had running boards or even nerf bars.
The transformer could be zip tied virtually anywhere if it is weather sealed. Make sure you have an on/off switch at the dash so you can turn it off if the cops don't like it.
Hope it goes well. Post a photo of the project when you are done. Make sure you use a tripod and no flash on the camera for the most flattering effect.
transformer?
Any Suggestions?
remember the transformer has to be mounted to a metal surface. this way you will have a stronger connection!
this is are old REGULAR NEON now we have LED under it!
  • 1 month later...
i would put the side tubes on the box of the truck... if you dont you will get cracks in the tubes... haha i found this out the hardway!! but its a streetglow kit and they have a lifetime warrenty so yeah.... the front i would put on the plastic skid plate! the rear one i would mount right behind the spare tire....and if possible get another kit and put on this inner frame so you will loose the dead zone in the center...but since its streetglow you may not have that deadzone..... :D
    bellssn690
    bellssn690
  • Who's Online   5 Members, 0 Anonymous, 718 Guests (See full list)
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
