Specs help
Ok guys I bought a 1989 k3500 dually with a 454 and a 4 speed Id like to know where i could de code the options and find out gear ratios of the tranny and power ratings for the year and all that fun stuff. Also is this a roller or non roller block? Im not sure when the Big blocks were changed to rollers. Thanks
Hopefully, the RPO sticker is still in the glove box. That will tell you the real axle gear ratio. The transmission you should have is the old Muncie 4 speed with compound low. 4th. is direct. The 1989 TBI 454 was rated at 230 h.p. and 385 ft. lbs., and is a non-roller lifter Mark IV. It is probably a 4 bolt main bearing block. Roller lifters were not used on big blocks until the 1996 'Vortec 7400' Mark VI.
Thanks man Theres a few stickers inside the glovebox ill take a picture of them and show you guys.
Thats all I have in their and something about camper loading and my warranty book and maintenance. Is there no tag or anything stamped on the rear end?
O.K., L19 is 7.4L V-8 (454), M20 is 4 speed manual transmission, 117 mm., GT5 is 3.73 rear axle ratio. The gear ratios for that transmission are as follows: 1st., 6.55 to 1, 2nd., 3.58 to 1, 3rd., 1.70 to 1, and 4th. is direct (1 to1). Reverse is 6.09 to 1. The case is cast iron. Hope that helps!
Here's all the codes I could read, and the translation:
AE7 = Split Bench Seat
AK9 = Seat Belts - Shoulder belts + center lap belt
AM7 = Folding rear seat
AU3 = Power door locks
A20 = Power Quarter Vent Windows
A31 = Power Windows
B32 = Floor Mats, Front
B33 = Floor Mats, Rear
CD4 = Intermitant Wipers
C60 = Air Conditioning, Manual Control
C7A = 10,000# GVWR
C95 = Dome Light and Dual Reading Lights
DF2 = Folding Stainless Steel Wide Load Mirrors
E63 = Fleetside Box
FF4 and FF5 = Torsion Bar Springs
F59 = Front Stabilizer Bar
GT5 = 4.10 Gearing :wtf: (not 3.73 . . .that would be GT4)
J55 = Heavy Duty Brakes
KC4 = Engine Oil Cooler
K05 = Engine Block Heater
K34 = Cruise Control
K60 = 100 Amp Alternator
L19 = Gas 8 Cylinder 7.4L TBI Engine (454)
MM4 = 4 Speed Manual Transmission Provisions :thumbs:
M20 = 4 Speed Manual Transmission, 6.55:1 Low :chevy:
NA5 = Federal Emissions
NJ8 = Dual 50 Gallon Fuel Tanks :eek::wtf: (I think this is a re-used code, my list is from '02)
NK3 = Simulated Leather Steering Wheel
NZZ = Skid Plate Package
N33 = Tilt Wheel
OSG = Built at Oshawa, Ontario, Canada
P06 = Hub Caps
P18 = Spare Tire with Hoist
R05 = Dual Rear Wheels
R7G = Sales Control #
R7K = Sales Control #
SLM = Stock (not Sold) Order
TP2 = Auxiliary Battery :cool:
TR9 = Lamp Group
UF2 = Cargo Light
UM6 = AM/FM/Cassette
UY1 = Radio Wiring Provisions
U01 = Roof Marker Lights
U37 = Cigarette Lighter
U66 = Custom Speaker System
U73 = Radio Antenna
VB3 = Rear Chrome Step Bumper
VG3 = Front Bumper Rub Strip
VK3 = Front License Plate Mounting Package
V22 = Chrome Grill
V73 = Vehicle Origin Statement
V76 = Tow Hook
XDL = ? (This code doesn't exist in my list)
X05 = ? (This code doesn't exist in my list) :uhoh:
YDL = ? (This code doesn't exist in my list)
The above 3 codes are probably front, rear and spare tires.
YD3 = Base Axle
YD6 = Base Rear Springs
YE9 = Trim Level 3 (Scotsdale? I'm just guessing)
ZDL = ? (This code doesn't exist in my list)
ZG2 = Sales Control #
ZV2 = Statement of Origin, Nominal Ton Rating
Z31 = Advance Price Sheet Identification
Z49 = Canadian Export Base Equipment Modification
Z53 = Intrument Cluster, Oil Pressure, Coolant Temp, Volts
Z81 = Camper Provisions
7GK = Computer Selected Suspension Component, Right Front
7BD = Computer Selected Suspension Component, Right Front
That's all I got. :jester:
    CaptainDad
    CaptainDad
  • Who's Online   0 Members, 0 Anonymous, 576 Guests (See full list)
