hummer h 2 wheels will they fit?
sdteb
Are you just sticking the original factor, plastic hub cover on there to cover the center? or do you use the H2 one?
The H2 ones don't fit. The Silverado hub protrudes out to far. The OEM silverado lug cover fits fine. Doesn't look quite perfect since it is a polished plastic and most of the H2 wheel is a flat silver.
i have monroe reflex shocks on it now...will that suffice? any one have the tool to crank the torsion bars? can someone show me how much i have to cut to get these to work? thanks
The only tool you need for the torsion bars is a rachet and a 18 or 19mm socket (can't remember right off which one). A tape measure is handy as well to get a side to side measurement to get it even and level. I didn't jack the front end off the ground to make the adjustment, but it would make it easier to turn the bolts.
they look sweet c5hd. when i get some more cash up, think i'll look for a set. any ideal what they are from the dealer?
I am not sure what they are from the dealer, I am thinking $100 - $150 per wheel. A set of BFGs is like $800. I've seen Dealers advertising take-offs for around $1000. What I did was look on e-bay for a set of low mileage take offs. they probably average about $550 for a set (wheels and tires). Wait for a set local to you that you can go pickup. Shipping is like $300 since they are so heavy.
which freaking bolt do i turn to raise it up?
a
Someone proabbly has a picture, but it is pretty obvious, you may just be looking in the wrong place. Is is about half way back about middle of the cab, and maybe 12" -18" in. It is protudes straight down and is at the end of torssion bar (opposite end from the A-arm). You can literally make a change in 30 secs. Just get a pick wrench/ratchet/breaker bar, because you need to apply a fair amount of torque.
