5.7 vortec oil pressure
Just curious. Mine is witin spec, but I expected it to be higher. I'm use to 40 psi at idle warm, and my truck is 20 psi (warm at idle in gear). I run 40psi while driving which is plenty. GM's specs are 8 idle and 25 at 4000 rpm. Just seems low compared to what I'm use to.
What do others trucks run?
  • 1 month later...
At 50k I had 20 psi at idle and 40 psi while cruising. At 95k it is has the same numbers.
