Painting Interior Pieces
I am wondering if it is possible to paint certain pieces of the dash to match my outside body color, or do you need to buy the aftermarket paintable dash kits? I was thinking of painting just certain pieces to accent the interior a bit. I am thinking that I could just take off the pieces I want to paint and then paint them, but will it look good, or has anyone done that?
Thanks so much!
I'm thinking about doing this on an 03 GMC Sierra,
If anyone has painted any of the stock interior pieces let me know how it turned out
Thanks
  • 1 month later...
red stimulates brain activity.................hmmmm i never knew that darn now that you mention it i do kinda have a head ache :seeya:
  • 2 months later...
on my old tahoe i painted the main dash piece, the air vents, and all the pieces that are around the door handles. i just used blue spray paint and it turned out shiny as hell
  • 9 months later...
Thanks
I painted the whole dash on the `97. Went to a local Sherwin Williams Automotive store. There are many paint stores everywhere though. I had them custom mix the paint for color match. They also have samples for all makes to choose from. $35 mixed with the thinner, so it was ready to spray in one of those $5 spray jars. Worked great, matched exactly and no one could tell. I learned one thing, If you like the finish of the dash, satin, and you want to customize it a little without those stickons, then this is the way to go. Wish I had pics.
First, scuff the pieces with a red Scotch brite pad, clean, and wipe with paint prep or alchohol to remove oils. Paint and let dry. Reinstall. Good Luck.
I painted interior pieces on my Subaru a couple of months ago. Before and after shot below. (the rest of the dash is still the same color but the flash makes it look different)
I started by wiping with acetone and rubbing alcohol. Then sanded with 400 to knock down the texture. Another wipedown and then shot Rustoleum plastic primer. I did a light sand, wipe and then shot Rustoleum Nickel Metallic. I did not sand these coats. Then I sprayed acrylic satin clear to simulate the aluminum look since I didn't really want a glossy surface.
The prep work is the most important. You can shoot a crappy paint job and if you hate it just sand and repaint. But if you have grease or oil (plastic likes to soak these into the surface), then you will get fisheyes during the paint or flaking/peeling later on.
    ar0517
    ar0517
  • Who's Online   4 Members, 0 Anonymous, 523 Guests (See full list)
