no power
I've got a 94 Z71, 5.7 w/120K, auto, came with a towing pkg., that runs fairly strong and well until I try to tow my boat to the coast(Texas).
Seems like it runs in third gear the whole time, runs at about a 215 temp, :D and forget going up a steep grade at speed. Shouldn't a 350 pull better than that???
yep thats a TBI fuel injection for you. Gutless wonder. These engines have always favor a manual trannys better, due having 5 gears. They like to be keep in the 2500 to 3000 rpm range for best pulling. I Had 2 of these style engines. both lost speed when going up a grade when empty!!!! One was an auto, one was a manual. The TBI engine likes a manual better, pulled decent in 4th gear, but ended cooking that gear. :crackup:
Here the problem:
350 cubic inches trying to suck air though two small holes, plus having 2 injectors above throttle plates for uneven fuel disturbtion. EQuals NO power. :)
solution:
step up to a ram jet 350 crate engine :D . With multi-port fuel injection and one big throttle plate. PLus nice cam. Equals nice power. Or just get a new truck! :(
I dunno,
Your truck has 300lbft of Torque. That should be enough to do anything a 1/2 ton is rated to do. You may have 3.08 or 3.42 gears bogging it down. You should have no problem pulling a 22ft or less boat up a hill.
Staying in 3rd is good thing.
We need more info. How big is the boat? How fast are you driving?
If you're towing across the Golden Gulf Coast Plain to the coast of Texas...there ain't many real hills!! I know...I grew up north of Houston :crackup: !
A 10 year old truck may have a bunch of hard miles...check the compression and see if you have a weak cylinder or two. You can't expect it to run in overdrive, or 4th gear on your 4L60, so in fact there may be nothing at all wrong.
Dave
