speedshifter Posted September 23, 2004 Posted September 23, 2004 Hey guys, Got a complete long block from an 02 escalade (6.0L 345HP) sitting here. Makes noise when cold from piston slap, and needs pistons. Anyway, I'm looking to get a '98 or '99 LS1 Camaro soon and was wondering if the short blocks were interchangeable between the Escalade motor and the camaro's ls1? If so I was gonna build up the short block 6.0L and put that in my camaro. Thanks for the info.
Butch 02 Denali Posted September 23, 2004 Posted September 23, 2004 Other than the oil pans, they should be the same externally.
speedshifter Posted September 24, 2004 Author Posted September 24, 2004 hey, now thats what i like to hear!! i get to use my free motor, plus get a little extra displacement to boot! heck yea!!
Tucson_02Silverado Posted September 25, 2004 Posted September 25, 2004 Are you goin' to bore it a bit and make a 427? Then get the 427 chevy fender flags.....
99Silver6.0 Posted September 26, 2004 Posted September 26, 2004 Get a 422 Stroker kit from SLP. The compression is higher on the LQ9 in the Escalade. It has beefier rods and different pistons too. The 01+ 6.0's have awesome flowing aluminum heads! I dont think putting a cast block 6.0 into a camaro is a good idea though. Your gonna add a bit of weight up front. Other than that it will all bolt up and the computer connections will hook up. EXCEPT for the injectors. LS1 and truck motor injectors are different. If you use the LS1 injectors on the 6.0 you will have to shim up the fuel rail because they are taller. You might also need to use the flywheel off of the LS1 too. Ive got a 6.0 im gonna stick a cam in today. You will make some nice power though. Stock cam in that 6.0 wont pull near as high as that LS1 will, gotta remember that. Stock LQ9 cam doesnt have the tight LSA of the LS1. The 6.0's are torquey. Cam it, put in some ARP rod studs and drop that baby in!!
