air bag light
if the airbags were triggered then you will have to change the clock spring in the steering column as well as the airbag module (shcek with your dealer on its location) It could possibly be under the carpeting under the drivers seat.
THe clock spring is behind the steering wheel and plugs in under the dash.
There are 3 lplughs you could check... CLock spring, one under the drivers seat, and one behind ther glovebox ...all yellow)
Why would you have to replace the clock spring if the airbags went off? Im not saying your wrong...Just wondering, for the clock spring plughs right into the back of the airbag...and seems like 2 seperate units.
Mike
Mike
The manufacturers want all of thos items replaced any time the vehicle is in an accident and the air bags deploy for safety reasons. Once current goes through certain connections they don't want them reused. We used to have to do the same thing at Toyota.
O.K. now that i have replaced all these thing and spent hundreds any other ideas?????????????
and yes the truck was in an accident. i have so far replaced the air bags the clock spring the front sensor the module under the seat with no luck clearing the light. :cheers:
It might require that the light be reset with the TechII...first you gotta pull a code and see if there is a problem, if all is well the code should clear with the scanner.
:cheers: ok thanks going to see now if i can get er'done
im not sure if applies to your model but there might be something to do with the seatbelt after a collison that needs to be reset/replaced
If the airbag light is on a fault is still present. You'll have to hook up to a computer that can access airbag codes and find out what the code is.
Did you replace the impact sensors under the front bumper/frame? They can only be used once and they are no good.
If this is the second deployment of the airbags in this vehicle the SDM is no good. It is only good for two air bag deploying incidents.
Hope this helps, let us know what code(s) you've got and we'll go from there.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
