RC B-52
MiSdIrEcTeD_1
OMG!!!!!!! F*** d**n!!!! :cool: I never saw that video and SH!T! What a shame, fcuking english weather! :flag: He should have or, he did notice, the wind turbulance on take off... Well no, that plane def. has the power.. Problem is the experienced pilots are like "what wind" and just take off and fly anyway, knowing they can handle the SH!T. Which i think he could have, watching his other video's. He can control that ~300lbs ( if i remember righ) very good, l;ike nothing at all. I call for mechanical/eletrical faliure!!! Prolly mechanicall failiure, I dought electrics would crap out since there to simple, he prolly stripped a servo in those high winds and crashed!!!
d**n
Did you guys catch on the web that this plane crashed two weeks ago at a model show in the UK.......not much left of it.....started a ground fire too....the owner must be sick....... :P:nono:
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
