Transmission goin' out?
Hey everyone,
About a week ago my transmission started acting funny. Sometimes, (usually in the morning when everything is cold) it will give me fits about going into Reverse. It will go, but it takes a second. Then when I am in Reverse it kinda stutters on me. Feels like something is stuck or something. And then when I shift to Drive, it takes it a second.
My only two theories:
a) Transmission is goin' out. Its a 94' 4L60-E (4.3L V6) with about 178k on the clock.
b) Fluid is low. I know there is something wierd about checking tranny fluid. Does the motor have to be warm or cold? I can never remember.
Thanks for any insight everyone.
Hey everyone,
As I recall, check it when warm and on a level surface. If you don't have an owner's manual handy, it might say on the dipstick. I recall seeing some dipsticks that say "check when warm" or something to that effect.
EDIT: check this site for additional info - various vehicles do it differently, I usually check mine when warm and in Park.
http://www.csaa.com/global/articledetail/0...57C2025,00.html
Good luck
Mark
I have a 94 z71 with a 5.7/4L60e 140k on trans, and it has always shifted into reverse hard, nice clunk, and then shifting back into drive takes a half second, and once after a off-road event that involved alot of deep water crossings I started it up later that week in the morning, and it was stuck in park, until I got forceful with it. I'd look at the torque converter going out first if it stutters on you in reverse
Check it after the vehicle is warm, on a level surface, and RUNNING! If you do not check it while the vehicle is in park and running, you will get a false indication.
Also, beyond the level, check the fluid condition. When did you last service the trans?
At 178k I think that trans has lived a good life and may be on it's last leg, but if the fluid is shot, when not give it one last try and flush it with all trickshift. What do you have to lose if you already have a failing trans? :nono:
  • 3 weeks later...
    • I am sorry if this was misleading. That was a document attached to our most recent work order number (Doc# 7105804) that summarized all the current updates. These programs were ‘redone’ in the past but these versions dated 4/1/2016 were the ones that actually made all of the problems disappear. These programs were relayed to the dealer from the technical services group at GM. Here is the exact wording on the last work order:   “Front view camera reprogramming with SPS. A new version of FCM software was released to the service dept. In addition to providing general robustness and stability enhancements, this update includes all enhancements from previous software version releases. SPS camera and calibrate camera. OLH to perform extended camera relearn procedure after camera calibration. Would not take with first GDS learn. Front camera SPS – BDYZ333157450 GDS2 – camera road calibration performed 2810835 Front view camera reprogramming with SPS LT 0.6 OLH – extended camera relearn procedure OLH LT 1.5”   I got the truck back on 4/8 – since that time it has been great no problems whatsoever. The lane keep assist, active cruise control and AEB all work very well around town and at highway speeds up to 80mph. During this time I had been away for a week and purposely let the battery sit without a batter tender. Even with the battery a bit lower there were no problems exhibited. I really think this one has it fixed after dealing with these issues over a couple of years. These new programs and relearn process when completed seem to make all the parts (and newer replacement parts) ‘talk’ to each other without any glitches. Hope this helps
    • I turned 72 today. My day began with a trip to the pharmacy to pickup meds for me and the dog and then a stop at my chiropractor before heading home. Once home I started the job of replacing the rear brake pads and one rotor on our 2018 Silverado which will probably end up taking me 3 days to finish, gotta pace myself you know. Sometimes I question myself on why I still do most of my own repairs but if I wasn't then it's more than likely I would be sitting in front of the TV all day. It seems like the list of things I need to do gets longer no matter what I accomplish. I'm not complaining but being retired was so much easier when I was 62.   Peace
    • google "bathub failure curve". Basically, any part of the vehicle can fail at any time.  It starts off as being more likely (early failure), then the failure rate goes down (but does not go to zero), then it goes up over time because it wears/ages out.
    • I went from every other day to about once in five since the rain abated. I'm not unhappy about that. Took most of the month for the ditches to dry enough to mow.
    • Good for you and her!   Lots of brushing and grooming to be done
