New Segway
Black02Silverado
wheres the H1 military style? Snorkel and waterproof to operate underwater, 1 inch thick titanium plating armor(although too bad for the guy riding it when that tomahawk hits)
can they go any farther past "too far"?
does that last statement even make sence?
