92 Electrical Problem
I have a 92 Gmc 1500 and I have a ground problem I keep getting told there is a ground from the frame to the head. I found the ground that goes from firewall to frame under condenser and there is another one that goes 5 inches and is broke bu I cant see where on the head it should be attached. They say it is on the back but i dont know how you can see back there??
I think on the older models there was a threaded hole on the back side of the right head just below the valve cover (3/8' bolt). You should be able to reach between the a/c unit and the head to feel around the back side of the head.
