Polishing buffers
Chris97K1500
Having been around body shops all of my life and after buffing many cars and trucks I'll suggest to go with the variable speed. Without some experience you will burn the paint in real easy. I have a variable and you can get in tight places with it. Beware- Keep the buffer moving and stay focused on what you are doing.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
