Nav radio upgrade
I am looking to do the Nav upgrade to my 04 Silverado. Do any of these models come with XM? My stock radio has XM, 6 disc and Bose w/sub.
Thanks
Bill
If you're referring to the OEM replacement,
They don't come with XM, but you already have it.
It'll adapt. XM, OnStar, RSE, etc will operate as if you had the Nav unit with your truck originally. XM is NOT part of the head unit.
Remember, you will lose your 6-disk capability unless you order a separate dash mount or remote factory CDX and harness. You can add this at any time later.
HTH!
Yes, before or after. Doesn't matter at all if it's the factory kit or XM direct.
As far as any action goes, maybe just the presets, if at all. I can't recall what the presets did, but big deal, right?
Thanks.... I plan on adding the XM to my Bose system sometime "soon" but would like to take that XM addon and transfer it to the NAV system if/when I do it.
The XM connections you have now will be the same with the (OEM) Nav HU. Regardless of the "premium" or "Luxury" type.
That's IF you have the type(s) mentioned prior. Other's interface types should work too, but there's always one that's weird. Besides, the Factory retro and XM - Direct will have the nice display and control on the Nav screen.
I hadn't tried a full-functional check with an XM-Direct on any nav screen yet, so ask around!
Im also looking to add a nav/mp3/dvd/cd/touch screen and the brand choice will prob be alpine... but i do not know if it will come with xm it would be nice :D:chevy:
XM direct may work. Connect it now to the OEM radio with the GM adapter but only buy it if it has an adapter for the Alpine model you want, also!
  • 2 years later...
Hi, not to hijack you thread, however you both seem to know what your doing. I have a 2005 Tahoe, and I want to replace the factory navigation radio with a factory navigation radio from a 2007 model. does anyone know if it can be done?
  • 1 month later...
Hi. I am in the process too of upgrading to a 2007 Nav unit. My problem is that I got the one that needs the Bose Amp to work. I already had it programed and have it installed. I want to obviously figure out the amp issue, I would also like to add a screen for the back seat, I have a crew cab 2007, so I can play DVD's as the Nav unit has a DVD player. I would also like to do the backup camera as well. Anyone have any ideas. Thanks.
    • Okay boys and girls I put a bottle of this in Dizzy the oil burning guineapig after a tank between the coil and plug service of the #3 hole and near the end of the first R&P 5W30 attempt. As a note I did a two R&P oil changes back in October of 2025 with little effect. Granted they were 1K mile a shot oil changes so.... Then followed by fourteen  1K mile changes of Mobil 1 Euro 5W30 FS. Also ineffective.    Anyone who has followed the adventures of Dizzy may remember that to put the oil on the full mark of the published nominal 5 quart change I withhold about a cup of oil. That over the last 50K miles the P0420 light has been a frequent flyer, sometimes three of four a day. And that even on 93 octane fuel she registers some KR even in moderate conditions on favorable days on slight inclines. Lastly when giving her a kick in the pants, something done about once a week, she looks like a diesel with the pump turned up. 😬   After one bottle and over the last 500 miles of a 3K mile OCI, of the first oil change I dropped the nastiest looking oil ever in her history. That's saying something as  you will recall I have used AutoRx, HP EC30/40 and a few other harsh solvents in her before including the GM top soak twice. This was syrup. Black stinky, inky syrup but the filter wasn't all that bad.    On the second fill I had to use the entire 5 quarts to reach the full mark. That was unexpected! The ignition KR is completely gone! Even at 99% engine load. MAP is much lower. Level road is now 9.8 instead of 12.5. Fuel economy is remarkably higher and for the first time since her earliest days she will spin to 6500, more than a thousand higher with out laying down dead. Yes, the coil and plug had something to do with that but remember the first 2500 miles after that repair on the first change it was same ole same ole Dizzy. Seems we have top rings that are somewhat functional again. P0420 code only comes on now if run in town for more than an hour of stop and go. On the open road it goes weeks without a incident. Perhaps it is cleaning the cat on the pass through?  Fuel Trims have improved as well. Nothing not to like.    To early to say about oil economy but the changes to date in the operational aspect is remarkable. I can't think of a worse case than Dizzy.... It's already paid for itself in a few tanks of fuel with the mpg improvement.    @OnTheReel, I'd say if the Jeep didn't respond perhaps there wasn't an issue to respond to.    I've run the Red Line SI-1, AMSOIL fuel cleaner, GUMOUT and Techron all in this SUV without any such results. Color me impressed. I'll be running out my supplies of the list mentioned and moving on to the Valvoline R&P Fuel System Cleaner.
    • Hey Chuck !!Thanks for the all the info I'm an old fart and I have everything I need for the oil change at home,minus flexibility .... and I’ve been doing my own oil changes for 40 years. I just didn’t want to end up without a crush washer or with the wrong one in my stash and have to walk to the auto parts store, lol. I climbed under the truck to check the location, and man, it’s going to be the easiest oil change and filter swap in the last 40 years—right up there with my 2014 Mitsubishi Outlander 2.4. No mess, nothing to drip on—just perfect. I’ve got one more free oil change to use, and then that’s it with the dealership!
    • I think this subforum was created for the new generation pickup trucks (2027-) with the 3.0 but I don't think it's a big deal either way. There are probably 2027 model-year specific changes for the SUV's too.   I was just curious if you had issues with your 2025 3.0. I'm still under 10k miles on mine and fingers crossed I don't have thrust bearing issues. I'm guessing not, since you're willing to buy another one! It's a good engine minus one or two manufacturing whoopsies.
    • Wife has enough metal in her she hides from the scrapper.
    • Djannoyed was a one hit wonder. Posted and disappeared.
