Sub Types
jake_33
ive got a 89 chev single cab and 2 12 inch pheonix gold x-max subs with a 1200 watt amp but the problem is my seat is right at the front becasue my box and subs are too big what kind of subs do u ppl run that sound good and the seat doesnt have to be at the front ..........and iam selling the subs if anybody wants to make an offer they can handle 400 RMS
Well, I have a JL Audio 10w6 (had 2, one got stolen along with the head unit a few months ago :cry:). I was going for good tight bass and sound quality more that I was SPL. That being said, I have been VERY happy with the sub(s). Also, since these have been out for several years, they're easy to find on ebay and such. When looking I also read several good reviews for Alpine Type R subs ... no personal experience with these, but if I remember correctly the mounting depths for the Alpines were a bit shallower than for the JL's. That may be beneficial for you with them going behind your seat. One last note, Alpine has several lines (as does JL Audio) so if the higher lines are out of the price range you still have options. :troll:
thanks for the info but ya how does the sound quality from 12s to 10s compare bass wise cause i used to have 4 kicker 8 inch subs they dint have very much bass at all but my seet was back but no bass so hard to decide
For a single cab, go with a pair of 10" Orion XTR DVC subs if you can still find them. I see them NIB on ebay sometimes for about $60 per sub. Go with a pair of these, a good sealed box, and about 400-500 watts RMS and you won't regret it. I had a setup like this about 4-5 years ago, and I had people comment often on how good they sounded. Once, three guys walked up to my truck after I had just parked in this parking lot, and I had been cruising with the stereo up. They asked to look behind the seat to see what subs I had, and their jaws dropped when they saw that I only had two 10" subs and an Orion HCCA 225 amp(about 400-500 watts). :ughdance:
I am running one 12' Memphis Studio powered by a Rockford Fos 500 watt amp.
(4) 15'in Reactors... Sounds Beautiful... Alot Of Power....
Last Set Up
(2) 15'in Kicker Solobaric L7's In Downfire Box MASSIVE POWER
Then
(1) 15'in Power Acoustik Mofo Heart Stomping!
First Set Up
(2) 12'in Sony Xplods Good Bump Sorta....
But Fer Ur Truck I'd Run With A Stealth Box! If They Make One! Or Else 4 10's That would be grand :jester:
  • 3 weeks later...
Currently I have 2 JL 10 inch subs powered by a 300 watt Rockford Fosgate amp. It isn't insanely loud, but I think it sounds great. I have also had good luck with Kicker and Rockford Fosgate subs in the past. If I had it to do all over agiain, I'd get a Kicker solo baric 12 and a Kicker amp. I miss having some storage under my back seat.
alpine type r's won't hardly fit behind the seat of a single cab truck. i have a 91 single cab and they would have fit, but my knees would have been touching the dash all the time. so instead i went with a 12" kicker solo baric L5 in a 1cu.ft. box. if you want a 10 you can step up to the L7. the 10" L7 and 12" L5 are basically the same speaker (same power handling, mounting depth, etc.) and i've got a fosgate amp pushing it, dont remember which one but it's pushing out a hair over 650 watts at 2 ohms.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
