'67 SS HAULR Posted December 30, 2004 Posted December 30, 2004 Hi All, I'm new around here... and I was looking for some help on some RPO codes for my '01 Tahoe that aren't listed here on the site. While I was able to find the majority of them, these ones were missing: AXP EVA FE9 FF6 FF7 JAN NF2 R7K SLM VXS V73 X88 YD3 ZM9 ZY1 X31 Z49 1SD 11U 521 522 6XK 7XK OK, so there were more than I thought Hopefully a few of you can jump in here and point me in the right direction. BTW, my tranny code is listed as M30... (5spd manual) even though it has a 4 spd automatic with tow/haul mode (M32). Anyone else ever run into wrong RPO codes listed on their build info? Thanks In Advance, Chuck
GM-Tech Posted December 30, 2004 Posted December 30, 2004 BTW, my tranny code is listed as M30... (5spd manual) even though it has a 4 spd automatic with tow/haul mode (M32).Anyone else ever run into wrong RPO codes listed on their build info? Not sure where you got that an M30 was a 5 spd manual. M30 is a 4L60-E.
'67 SS HAULR Posted December 30, 2004 Author Posted December 30, 2004 Not sure where you got that an M30 was a 5 spd manual. M30 is a 4L60-E. <{POST_SNAPBACK}> I got it right off the RPO page on this site It states: M30 - MAN 5 SPD M32 - 4L60-E
GM-Tech Posted December 30, 2004 Posted December 30, 2004 Not sure where you got that an M30 was a 5 spd manual. M30 is a 4L60-E. <{POST_SNAPBACK}> I got it right off the RPO page on this site It states: M30 - MAN 5 SPD M32 - 4L60-E <{POST_SNAPBACK}> It's wrong. I have the RPO list of all time from GM in pdf form if you'd like to see for yourself. It's right HERE.
'67 SS HAULR Posted December 30, 2004 Author Posted December 30, 2004 It's wrong. I have the RPO list of all time from GM in pdf form if you'd like to see for yourself. Ahhh... I've found the man with many answers! That is quite the list, thanks very much! I guess someone should change the RPO page to reflect the correct info... some so other newbie doesn't make the same mistake.
GM-Tech Posted December 30, 2004 Posted December 30, 2004 I guess someone should change the RPO page to reflect the correct info... some so other newbie doesn't make the same mistake. The administrators here are welcome to the pdf file. I can't remember exactly how I got it at the dealership, but it is an "official" RPO list from GM and not something someone came up with on their own.
GM-Tech Posted December 30, 2004 Posted December 30, 2004 GM-TECH if it has not been said you ROCK Thanks!
