Warning, adding factory trans cooler
The cooler itself was easy, especially since the grill, air intake, and all the plastic parts come off so easily. The short cooling line wasn't too bad. The other line, tho, is a long one, goes from cooler all the way back to the trans. Looks like a real PITA to replace that one, so I am going to splice the new into the old.
Got the kit off eBay, and definitely should have looked at the job before buying it. Looks like an aftermarket would have been a lot easier.
It can be done, but i suggest you check out this thread:
Factory Trans Cooler DIY Info
Let me know what you figure out. Mine works very nicely now, but I dont think i want to do that job again. Errr, no, i never want to do that job again. Ever.
Well, after reading that, I am definitely goint to cut the front off the old line, the rear off the new line, and splice it with some 3/8" tranny hose. That leaves only one clip that has to come off.
I thought they all came with them already, no? Pretty sure I have one, I have the little radiator in fronrt of the big one. :devil: I do have the tow package though, so that could be why it's there.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
