Running Hot at Highway Speed
:devil: Anybody have any suggestions on what would be making my truck run hotter than normal if i get on it on the highway. Im presently running the twin flex-a -lite fans , 160 hypertech thermostat and a radiator from a 1995 Suburban 2500 series. Its my understanding that the fans should not even be running while on the highway, that the airflow from moving would be enough.
Also the water pump was replaced with a new GM unit about 30,000 miles ago.
Its not like it overheats, but the temperature gauge can go to full. As for regular driving, the temp stays in the middle of the gauge.
Warm only at highway speeds? Not hot at city speeds?
I think you have something blocking the front end, blocking airflow to the radiator.
You are correct that you shouldn't even need fans when driving at highway speeds. Aerodynamics can play a big part in what you're experiencing.
For example, a number of years ago we had a similar problem in Camaro's. If you damaged or removed the little black deflector that hung down off the bottom of the radiator core support, they'd overheat the minute you got on the highway. You could run all day in 90 degree temps and stop and go traffic and never have a problem, but at high speeds, it overheated pretty quickly, even on days that weren't that hot.
The problem was that without that little deflector, the airflow characteristics where changed enough that turbulence upset the airflow through the radiator. That little piece didn't seem that significant, but everything is there for a reason.
So, depending on what you've changed/modified/removed in the front of your truck, you may have created a similar problem.
The only change to the front of the truck was changing from an aftermarket bumper to a GM Z71 style (diesel bumper with the openings in it) I think that would allow even more airflow.
I gonna hook up the scanner to see what the temp is actually reaching tomorrow.
* lower raidator hose collapsing under higher vacuum while cruising ?
* cracked head or blown head gasket ?
* timing retarded?
* timing retarded?
I wouldnt know if the radiator hose is collapsing ( i doubt it , they have the wire insert)
no oil in the coolant, no smoking out the tailpipes, no coolant in the oil
Distributor hasnt been out or touched and reads correctly on the scanner.
Any other ideas?
I had a similar problem with my 91 s10. The problem was a clogged radiator. I replaced it with a new one and the temperatures dropped to normal.
Jeff
Jeff
I thought of that, I put that radiator in brand new (GM) last May.
Could it be that the shop that installed it originally filled up the coolant with the green coolant and I ran that for awhile before switching back to the dexcool?
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
