Suspension Option
Does anyone have the Manual Selectable ZX3 suspension option?  How does it compare to what you had before and are there any downsides?
Yes, you apparently can chose between smooth (Z83) and (Z85) shock damping for  ride and handling.
I got some info from an owner (ChiefZUSAF).  Here is what he told me:
"I have the ZX3 package (orange shocks) on my 01 Silverado. It is a button located next to the "passenger air bag off" switch" that electronically controls the ride. The "soft" ride mode is nice and comfortable much like a car. The "firm" ride mode is definitely a harsher ride except when you have a load then it isn't too bad.
I had a 99 Sierra with the Z85 firm ride package (blue shocks) on it and the ride was comparable to the "firm" mode on my Silverado"
and "The shocks are manufactured by Delphi and are orange in color...when I looked under the truck it appeared that each shock had an air line going to an air pump in the engine bay.
However, a good friend of mine (bigtime GM nut and co-worker in the US Air Force) told me that those were not air lines...he said they were electrical lines that are connected to the shocks which contain some kind of new-tech gel...once you select the firm mode the electrical signal causes the gel to firm up. Now, I have not verified any of this with GM or Delphi...I can't say if any of this is factual. I will do some research and find out now that you have re-engaged my curiosity"
I have the FW1 Ride Control on my 2002 Sierra Z71.  I believe the FW1 is the same as the ZX3.  The shocks under my truck are also orange and made by Delphi.  This is the first year that the Z71 is offered with the ride control.  Personally, I love it.  It has the same switch as the ZX3 (Firm vs Normal mode).  The "firm" setting is definitely firm but rock solid.  It is definitely more firm than my S10-ZR2, and the normal setting is equivalent to a normal Z71 ride.  I haven't towed anything yet, but I'm guessing that the firm setting will be great for that and offroading.  I can also corner a lot faster in "firm" than "normal."  I have added BFG A/T 265/75's and that might make a little difference.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
