Differences between Silverado 1500HD & 2500HD
hello,
I just put an ad to find a Silverado 4x4 crew cab to tow my wooden boat. The weight of it with the trailer will be around 8 500 pounds.
I am looking for a 2500HD with a duramax/Allison combo.
But I was thinking that may be a 1500 HD with the same engine.gearbox will do the job. So what do you think ?
Thank you for your help...
Jacky :D
Oh, I remembered another one.  The 15ooHD comes with 3.73 gears only.  You can get 4.10s in the 2500HD
Not True - just bought a 2004 2500 GMC (which is the same as a 2005 1500HD) with 4.10s. Go to the GMC website it is an option for the 2005's.
Yeap, RPO-GT5(4.10 Gears) came with my '03 1500HD.
I would expect the rear end also to be tougher on the 2500HD, but dang my 1500HD came with a 14 bolt, & a 4L80E!!!
The 2500HD's available option Duramax would help towing cause of it's lower torque curve & tons more torque. Horsepower is about the same between the 6.0L Vortec(1500HD) & 6.6L Duramax(2500HD-3500).
Ron
there are 3 different 14 bolt rears:
9.5"
10.5"
11.5"
the 1500HD's comes with the 9.5"
The 2500HD's have the larger ring gears, a taller frame, larger spindles and ball joints.
9.5"
10.5"
11.5"
Actually, All 8600 lb GVW 1500HD & 2500 trucks built after 9/2000 all use the same front end components as the HD and 3500 series. The front suspension components of all these trucks except for the torsion bar rear cross member and torsion bar torque ratings(GK and GL) are all the same. :D
RPO code for Allison 5-speed Automatic is M74. You probably won't find a D-max with any other tranny because the "take" rate for the Allison si over 97% (meaning less than 3% of D-max trucks have the ZF 6 speed manual trans.)
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
