Yukon Oil Change
:D to all,
Scanning the boards I haven’t found any threads with relation to changing ones own oil. I have a 2004 6-month new Yukon and I need to change the oil; I am a bit cautious of how I approach this as my experience changing oil has been only with my C5 Corvette which is quite the process.
Specifically, are there any gotchas with doing the oil change yourself? If a previous thread is available I will most certainly read - however, as of today any search for "oil" in this forum results in an invalid search... strange :wtf:
Thanks...
scubaboy
Nope, pretty simple process. Remove drain plug; drain oil; remove oil filter. When the oil stops draining, or you get bored, re-install plug and new oil filter. Refill oil.
Take used oil to a designated recycle facility.
IMHO Mobil 1 and a Mobil 1 filter for best results. Reset the oil computer so that it doesn't flash at you. Drive as normal.
I have to agree with DJinCO especally on the Mobil 1 and dont forget the grease zerks on the front suspension & steering linkage. :wtf:
Stupid question here... My '97 didn't have an oil computer, but I'm guessing the 2001 I just bought does. How do you reset the oil computer?
Turn key to run (do not start)
hit accelerator pedal 3 times within 5 seconds
Change oil flashes........done.
Like DJinCO, I run Mobil 1 filter and oil and change every 5K.
Do the stuff already mentioned. I would also inspect the drain plug seal and replace if bad. I would fill the new filter with oil and I like to remove the oil filler cap when draining so there is no vacum. I would tighten the drain plug to factory specs,my Sierra is 18lbs.
I forgot to say that the oil will shoot out about two feet past the drain plug. I make a small wall out of cardboard and stick it to the drain bucket,otherwise you will have a big mess.
I have to agree with DJinCO especally on the Mobil 1 and dont forget the grease zerks on the front suspension & steering linkage. :thumbs:
I was doin my zerks yesterday and had to pretty much take the front tires off my truck. Plus i saw that grease oozed out cracks in the upper and lower rubber joints like on upper and lower balljoint and tie rod ends. It came out of very small cracks it seemed. Should I really worry or just make sure there is grease all the time in those joints?
Hey all,
Thanks for the tips... the oil change went off without a hitch except for the oil stream that shot out two feet from the drain plug; wish I would have read 'blasteros' comment before hand -- would have saved me some kitty litter :D
As for the grease fittings, I didnt do that. The Yukon has 3300 miles on it, how often do the grease fittings need to be filled? I saw the grease gun at Walmart but am not quite sure how to perform the process :chevy:
BTW. Changin the oil on the Yukon is a breeze compared to the Vette, but somehow not as rewarding <<sigh>>
Regards,
Scubaboy
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
