Audio Stuff
GMracer
JL AUDIO- 8" Subwoofer $50
The 8W3v2 is a remarkable 8-inch subwoofer with very long excursion capability, designed to extract maximum performance from moderate power levels. This speaker works extremely well in very small sealed and ported enclosures while its dual voice coil design gives the user a high degree of application flexibility.
Nominal Diameter: 8 inches (200 mm)
Continuous Power Handling: 125 Watts
Voice Coil: 1.43" diameter, 4-layer, Kapton former
Available Configurations: Dual 2 ohm, Dual 4 ohm or Dual 6 ohm
Xmax (one-way, linear): 0.38" (9.5 mm)
Sealed Enclosure Range: 0.30-0.50 cu.ft. (8.5-14.0 liters)
Ported Enclosure Range: 0.60-0.90 cu.ft. (17.0-25.5 liters)
VRC™ Technology: YES
Elevated Frame Technology: No
JL AUDIO- 250/1 AMP $320
Rated Power:
250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
THD at Rated Power:
<0.05% @ 4 ohm
S/N Ratio*:
>95dB below rated power
Frequency Response:
5 Hz - 500 Hz (+0, -1dB)
Damping Factor:
>500 @ 4 ohm/50 Hz
Input Range:
switchable from 200mV-2V RMS
to 800mV-8V RMS
Dimensions:
10.25"L x 9.25"W x 2.36"H
Features:
Differential-Balanced Input Topology:
(1 pair of inputs)
On-board Crossover:
fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
Preamp Output:
2-channel (full-range, LP or HP)
Bass EQ:
variable boost up to 15dB
Infrasonic Filter:
defeatable 24dB/octave at 30 Hz
Signal-Sensing Turn-On:
permits operation without remote lead
Dual mono speaker output connections:
accept up to 8ga. wire
+12V and Ground connections:
accept up to 4ga. Wire
JL AUDIO- Custom Stealth Box $120
Box is made to fit under rear seat in an extended cab Gen III dodge dakota, holds the one POWERFUL JL 8"
Make me an offer, Im open to negotiate, must sell! please!
