Add on tansmission oil cooler
I would like to get some advize on adding transmission oil cooler to my 2000 GMC Sierra 4x4. Truck has 4.8 liter engine and 3.73 gear ratio.
I am going to sometimes pull a small 5th wheel, 5000 lbs.
What type of tranny oil cooler I should look for?
Is a good idea to also add a transmission oil temperature gauge?
Ziggie
Ziggie
B&M Supercooler Part #70264, 24000GVW. Has all the hardware you need to install. If you want to add a tranny temp gauge you can look into getting a Denali or Escalade instument cluster. They have the gauge already there and its a plug and play deal. No modifications necessary to get the gauge to work. Only thing really necessary is the mileage transfer.
Ziggie
I have a factory GM cooler and the lines if you are interested. It was a kit from GM that they sent when some of the trucks got out of the plant without the cooler for the trailer pack. All new, never installed. email me if you want.
Ziggie
you would be better off with the b&m cooler. stock cooler suck, b&m coolers are about $60 and well worth it
Does the kit from B&M has all I need to have proper installation?
Is the kit one fits all?
Would you have a picture of the install on GMC truck?
Ziggie
Ziggie
Yes. It will have all you need.
So, I've got B&M cooler, not sure if I have all I need as I have a quick connect type connections at the radiator. I will have to remove one quick connector from the rad and put on hose adapter, then put another hose adapter on the radiator.
I think 2 of the 4 hose adapters are the right size. The supercoller will fit nicely in front of all the rads, have to drill couple of holes in the brackets after removing the grile.
Looked at it today, consulted Haines manual, should be no problem mounting it.
But here is another important question, which is oil return line from rad to transmission, upper or lower.
The manual says two things:
"On most General Motors rear wheel drive trunsmissions the oil line running to the upper fitting is the oil return line",
but on the Chart 1
General Motors
4L80E cooler line location
oil out of transmission: Upper
Oil return to transmission: Lower
So, which is the Oil to transmission return line, one going to the upper or lower connection at the radiator.
I know I can do the oil flow test, do not want to make mess though, I also have a friend with 2003 Chevy Z71 and tells me he has factory cooler, so I will go look at his.
At work I also drive the 2003 Chevy 3/4 HD with 6 liter, not sure if that one has axiliary cooler, will have to check on Monday.
I think the lower rad connection should be tranny oil return line, but not sure, for sure I will make it right, if I have to, I will do the oil flow test.
Again, this is on 2000 GMC Sierra, 4.8 liter and 4 speed automatic, I think the trany is 4L60E, tried to crawl under today to see for sure the type of the transmission, but I am too fat to fit there :D
Thanks,
Ziggie
Every late model GM truck I have owned the one on the top is the return line to transmission. The reason for this is the water flows through to tank and then down to outlet over tank tranny cooler. You want the hottest oil at the bottom where the water has already been heated some from above so there is the greastest possible tempature differentail for this water that has already been heated some from above. As the oil flows up tank cooler it is cooled more by water fresh from core cooling moving down over it. So you want to take outlet from tank cooler (top outlet) and hook it to aux cooler and then cooler aux output to tranny return line.
:D
:D
Maybe that is why I have piece of flexible rubber hose (8 inches or so) on the line connected to the top of the rad, this makes it easier for installation of Aux cooler.
The other line, connected to the bottom of the rad, is all rigid.
Ziggie
  • 1 year later...
I can confirm (added tranny cooler) that the top connection is the return (to the transmission) line.
:shakehead:
Ziggie
You made the right move by adding the cooler. I am not familiar with the B & M cooler but hope it is a stacked plate style cooler and not the tube and fin style. The Tube and fin styles are ok but you must use a much larger cooler to get the same cooling as a much smaller stacked plate design.
One thing I would consider is a fluid exchange to a premium syn such as Amsoil, especially if you will be towing any at all. Their website is great and will provide great instructions on flushing out your old fluid and replacing it with all syn.
I did it at home in less than 1 hour, you just have to have an extra person for part ot the procedure.
Again, you have taken a huge step in extending the life of your trans with the cooler.
I have a question for you guys. I have a '99 Z17 with the towing package which includes the factory tranny cooler. Can I add the B&M tranny cooler in while still using the factory one or do I have to replace it with the B&M unit?
Thanks guys.
Thanks guys.
Unless you do some wild towing, I would leave what you have. Aftermarket hoses and stuff never seem to be as well done as the factory (unless you do something special on your own), and every hose and connection is a potential leak, with ensuing failure. If you do put one in, I do like the stacked plate ones better, they seem a lot sturdier, and have real flanges to mount. Take your time and do it well if you do add one. Just my 2cents...
    • Ok that confirms the extra quart theme they are still going with which must mean they have noted some initial use more so then some engines and probably the bigger factor in all of this probably isn't the engine so much as its the insane distance or OLM that lulls a lot of the driving public into driving their new vehicle off the lot and not even doing one short interval oil change because the manufacturer doesn't say different and if the dealer follows that logic as well. Selling the rarely needing to be serviced concept seems to go over well with the public that wants to get away with as little as possible for dollars spent on the vehicles maintenance and I bet there are 3.0 engines just like other vehicles out there that never have their oil checked by the owner which goes back to why they probably felt the need to add that extra quart to avoid a costly theme.    Speaking of cutting filters open, it was probably over two years ago now that a youtuber who buys vehicles to do longer term reviews and pulls a fifth wheel through the mountains of Colorado on summer trips and that becomes part of the testing. Anyway he had a GM HD with the 6.6 gas and a Ford 250 with the 7.3 gas at the same time and of no surprise the Ford had more power etc but somewhere along the way in the few thousand miles he put on the truck, he changed the oil and was seeing glitter and cut open the filter and yeah, things were not looking spectacular. The truck about that time or soon after seemed down on power compared to what it had been and then threw some engine code, I expect the cam/lifters were failing and so he brought the truck back to the dealer and made some deal to get out of it as he knew it would sit for months waiting on a new engine as they were so backlogged at the time. He kept the GM for some time after that using it exclusively until he sold it after buying his next vehicle to do a review on. Definitely the filter can tell a story when things are starting to go sideways, but it would be a sickening feeling to cut it open and be faced with an ugly mess like that and be running a magnet through the pleats and the oil on the dirty side of the filter and see all the fines sticking to the magnet.    The dealer may have some ideas based on experience as to where that coolant smell is coming from, I would imagine if they can't find it but its smelling they would put dye in it to they could give it a run cycle and use the black light to see where it pops up, if its a hose connection, water pump, rad or even a head gasket etc.
    • Good looking truck, suspensionmaxx looks like a solid option
    • Thanks for the info, im considering a leveling kit or 4" lift kit.
    • charm.li (website) has the vehicle-specific diagnostic procedure for that code, you can use to find what the cause of it is.
    • It’s at the point of amusement. I’m retired I have time. It’s fun seeing people try to convince me I’m using oil. I’m buying oil at the prescribed time. It gets drained and new goes in. Do I add in between, no. My oil doesn’t even get dirty in 5k miles. I don’t even see any drop on the stick. I check in the same place. All is well.
