You southern guys don't have to respond... We know that they don't salt your roads. For the northerners: Anybody have a good way to get rid of the salt that biolds up on the carpet after a tough winter? Spring's here, so it's time to make the truck look clean and take the Husky floormats out.
Thanks,
Matt :rolleyes:
I usually start with the shopvac, then move onto to spraying some carpet cleaner, letting it sit for a little bit, then using a d**n sponge or rag to get things clean.
  • 6 months later...
Thanks,
Matt :fume:
My truck flipped out when I was in Detroit just before Christmas last year :confused: I liked how no one would get near me when they saw my GA plates...crazy southerner can't drive in snow and ice. Ah, but they didn't know I drove in Indiana winters for 10 years...hehehe.
Anyways, I took all off all of the trim at the bottom of the door sills and went crazy with just a sponge and some water. I pulled up the carpet and wiped the floorpan out really good too and propped the carpet up until everything dried out.
You need to dissolve the salt in water and then suck it out with a wet/dry vac.
I use a weak solution of dish washing detergent in water, and a stiff brush. The mild detergent will improve the penetrating ability of the solution. Brush some in, wait a few minutes, scrub it again, with more solution, and usually it stops being white right around then.
The carpet has a waterproof backing so all you are doing is getting the pyle wet when you scrub it. You can get it pretty wet and then just use a shop vac and it'll be pretty close to dry. The water's not soaking through the carpet into the pad.
Don't forget to get the water out of your shop vac after you finish, or you'll end up with a moldy shop vac. :fume:
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
