sea foam
if i use sea foam through my brake booster as a top engine cleaner. will it clean out my
fuel ports and injectors. my stealer said i had stopped up fuel ports and needed
to be cleaned out and wants to charge 120.00 plus if it fouls the plugs to replace
them total charge 180.00 what do yall think all this is because of hard starting prob and some missfire dealer already replaced cat,dist cap, rot button, brand new ac plugs and still has promblem with cold start and then misses at times on high accel after engine wrms to op. temp
No it won't clean out the injectors as it doesn't actually pass through the injector but through the intake valves.
For your plugged injector problem, you could try a couple bottles of Techron FI cleaner or berryman's B-12 in the tank. I have had good luck wth those 2 in the past. Put in a double dosage for a tank and followup with a regular dosage tank and you should be good to go.
Hard start could also be fuel pump or fuel filter problem but I'm assuming your stealer has diagnosed those as ok.
Good Luck.
I would run 1 can in the brake booster and dump 1 can in the gas tank or double up on the tank. I would even run a tank of high octane gas with it just for good measure. Its gonna smoke real bad when u put it in the brake booster, just follow the directions on the can.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
